Results 1 to 6 of 6
Thread: VN Problem, Help needed
    VN Calais
    Oct 2006
    Default VN Problem, Help needed
    Recently i've been having an unusual problem with my '89 VN Calais,
    It doesn't happen all the time but happens without much warning, the car feels heavier than usual, a lil sluggish, when at a complete stop or even rather slow, when i push the accelerator the revs just completely drop almost to 0, if i take my foot off the accelerator for maybe half a second then reapply it the car just takes off, if i keep my foot on the accelerator the car dies, and its hard to get restarted, normally pumpin the accelerator like crazy will get her going again and only if i rev the absolute guts out of her for about 30 seconds otherwise it just keeps doing it, its starting to get really annoying.
    Fuel pump has been discounted simply because its been replaced and still works done the whole "listen while its turning over thing" and is working fine.
    Any suggestions would be great.
    J
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    VN Calais
    Oct 2006
    thanks
    any other possible reasons why it'd be doing it?
    Just to have bases covered.
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    Coolant temp sensor could be dead.
    When my fuel pressure regulator went, when i pressed the go peddle there was a pause and seemed like it was going to stall then it would kick in and go. The same symptoms occursed when the coolant temp sensor went, i thought the regulator died again and made the mech test his work, but ti was the coolant temp sensor.
    VN Calais
    Oct 2006
    my water pump is leaking... could this be contributing if its something to do with the coolant temp sensor?
    KRUPTD is offline VN BT1 5L
    VN BT1 5L,5spd,LSD
    May 2007
    Griffith, N.S.W
    Check your fuel pressure mate.Make sure the fuel pump is supplying enough fuel flow and sufficient pressure.Also check the fuel reg for leakage.Very common on VN to VR's.Just pull the vaccum hose off the top of the fuel reg and check for fuel,if fuel is present you have a leaking fuel reg that is leaking fuel into the inlet manifold and making it hard to start.Also loosing fuel pressure whilst starting and driving.But if this is not the case would check the resistance on the ignition leads,if too high a resistance would suggest replacement.But to me sounds like a fuel problem.
    (KRUPTOR)VN BT1 5L TTB's,MANUAL,LSD
  1. VU SS Fuel Filter Problem! Urgent help needed!
    By liquidforce_134 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-01-2008, 03:58 PM
  2. Help needed Trans problem.
    By Dragz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-03-2007, 08:48 PM
  3. vr berlina wiring diagram needed, climat control problem
    By vrberlina5sdp in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-08-2006, 09:20 PM
  4. Electrical problem? HELP NEEDED ASAP!
    By Shifty1 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 01-12-2005, 02:30 PM
  5. A real problem solver needed for this one!
    By miz_fiesty in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-07-2004, 11:08 PM
