Results 1 to 13 of 13
Thread: Friggen T700, what's the problem
    VP 5L Calais
    Mar 2007
    S.A
    Default Friggen T700, what's the problem
    after being rebuilt with a B&M stage 2 shift kit, my trans doesn't want to change into overdrive at 180+km/h, if i back off the throttle it changes up but as soon as i try to accelerate again it kicks down to 3rd and winds out to 220km/h, more if i want it to, it will probably go to redline, i let off at 220km and it changed up, but as soon as i tried to accelerate again it kicked down to 3rd at 220km/h, and went straight to redline, i do have the kick down set at maximum tension but this still shouldn't happen should it?
    eurekamad94's Avatar
    eurekamad94 is offline street kiddo
    kitted, tuned, sick pantha VS
    Jan 2008
    qld
    where were you doing 220 ive got nothing against with a going for a run but thats simply too fast ps mods wont like
    Eureka styles!
    VP 5L Calais
    Mar 2007
    S.A
    contolled environment, i had to test the new trans, make sure it was working right, and guess what, it's not, and i wouldn't have found out unless i did that speed, so i gotta sort it out before warranty expires
    Boonz's Avatar
    Boonz is offline the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    VP 5L Calais
    Mar 2007
    S.A
    well i kept clicking it tighter until, when the throttle was full the adjuster clicked loose, then i set it one notch from where it clicked loose at full throttle, so it is as tight as possible, but doesn't affect all the other gears
    Boonz's Avatar
    Jul 2005
    usually with shift kitted transmissions you go .......tight cable,full throttle(engine off), then back it off 2 clicks
    its got something to do with the boost valve being bigger
    VP 5L Calais
    Mar 2007
    S.A
    Boonz's Avatar
    Jul 2005
    and it wont go into 4th at full throttle anyway only under less than half throttle with those settings
    VP 5L Calais
    Mar 2007
    S.A
    Boonz's Avatar
    Jul 2005
    yeh thats how i had mine setup with the shift kit and its how ive setup all my mates cars with shift kits and it works fine.... you can adjust it to how you like anyway cos different drivers liek different trans action
    VP 5L Calais
    Mar 2007
    S.A
    yeah i want mine to hold gears as long as possible and to kick down at higher speeds in each gear, but obviously i went a bit too over the top, might be working the trans too hard having it set like it is, maybe that's why it packed it in be for i got it rebuilt.
    VP 5L Calais
    Mar 2007
    S.A
    the kick down cable being too tight was the cause, i loosened it 1 notch and it's all good now.
    savage1987's Avatar
    savage1987 is offline fail champion
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Yeah they're pretty much not designed to be able to do 180+ in 4th I think. Same sort of thing as the electronic fuel shutoff as I understand it, I could be completely wrong though. And as if it was in a controlled environment.
    WTB: mulberry VN interior parts
  1. T700 weak?
    By Shifty1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-01-2008, 12:19 AM
  2. f.s: vs V8 T700
    By SNAFFLER in forum Parts And Other Items For Sale
    Last Post: 18-02-2007, 06:56 AM
  3. t700 not locking up
    By MontieVHSL/E in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-07-2006, 06:04 PM
  4. VN t700 Auto
    By chopsy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-06-2006, 02:37 AM
  5. T700 Diagrams
    By Chuff in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-12-2005, 01:03 PM
