Results 1 to 5 of 5
Thread: Boot leaking
    CLE
    CLE is offline
    Mar 2005
    Default Boot leaking
    Hi all,
    For the last couple of months my boot has been leaking. A couple of times I've had to remove a lot of water from where the spare wheel sits. That's where most of the water is collected. Also, there's usually water on the far right-hand side of the boot right on the edge there, plus under the carpet pretty much all the way across from left to right.
    The boot seals look okay and they're never wet on the inside. I just can't see where all the water is coming from!
    It's very annoying because I don't want any rust happening and my car smells (well, the boot does anyway).
    Thanks for your help!
    Cobez's Avatar
    Cobez is offline LS-EXUAL
    2004 S2 VY SS Ute
    Feb 2007
    Usually, the leak comes from the rear quarter windows. Water usually leaks in through splitting seals and leaks into the wheel well.
    Quote Originally Posted by wikky
    As already stated, mate you're an absolute gherkin strummer.
    dufus is offline Donating Member
    rickshaw
    Jun 2006
    CLE
    CLE is offline
    Mar 2005
    Jun 2006
    yeah get out the silicone and go over the seals of the rear quarter windows just try and make it neat.
    Also the tail lights often crack from old age and the sun so check them over & f you see slight cracking then go over that with silicone and smooth it out with your fingers.Also where the red/white/orange meet can crack there as well so I basically ran a seam of silicone around every joint of the rear lights.
    I have used atleast 2 tubes off silicon on my car to stop leaks and I have
    Another option is to get a friend in the boot with a torch and go over the boot/lights with the hose. But I can tell you it will be your rear quarter windows & also the rear lights, even go around the rear lights were they join the body of car as the seal goes bad there as well.
    Vn executive 1990 200,000kms as of 13/6/08 , oil changes every 5000kms since it rolled out the factory , strut brace for hard cornering, kn pod filter, Ngk iridiums sports exhaust..what else can I say I love my holden
  1. Boot leaking? Wah!!
    By Heffer_Slayer in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-01-2011, 06:40 AM
  2. boot leaking
    By Haydz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-12-2007, 05:50 PM
  3. boot leaking
    By ad45 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-11-2007, 04:40 PM
  4. Boot Leaking
    By Lozzza in forum VL Holden Commodore (1986 - 1988)
    Last Post: 24-11-2006, 09:30 PM
  5. VK Boot leaking
    By VKNutt in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 02-03-2006, 02:50 PM
