Results 1 to 3 of 3
Thread: Sweet Jazus
    Casso is offline FastFogey
    VNS2 Auto
    Apr 2007
    Question MAP Sensor Problems and wiring stuffup
    My VN with a VR engine is really driving me NUTS, I come up with error 34 map sensor, have changed it 3 times.
    I done the fault check and I get a whirry noise from the MAP sensor, when I short out BK/BW on the aldl the thermo does not come on, just this noise from the map sensor, can somebody please put me out of my misery
    I checked the wiring to the map and instead of 3 wires BLACK,GREY,Light GREEN, there are 4wires LIGHT GREEN,LIGHTGREEN/BLACK,LIGHTBLUE,LIGHTBLUE/BLACK.
    The other 3 wires I found in the harness taped up and only connected to the ECU, has anybody got any ideas???? Thanks
    WELLL!!!!!!!!!!!!!!!!! the problem was, what I thought was the map sensor,wasn't it was something on the throttle body with 4 wires,now we all know that the map is mounted on the firewall!!!!!!!!!!!!!!!! DON'T WE??????.
    When I done the conversion I was told that the map sensor was to do with the A/C, seeing as I wasn't using the air I left it out.
    Which brings me to the SUPPOSED handbooks of Max Ellery, a complete waste of paper, I'm going to start saving my used loo paper, as I'm sure I can interpret more out of that than Ellerys CRAPPY MANOOLS.
    Thanks to "just a stocker" for his input
    VP exe
    Sep 2007
    nope no idea but just check the continuitynof the wiring with a manual, keep in mid the ecu circuit could be gone.
    Gone Fishing...
    KRUPTD is offline VN BT1 5L
    VN BT1 5L,5spd,LSD
    May 2007
    Griffith, N.S.W
    If you have replaced the map sensore with (new items) and still throughs the map sensor fault i would suggest looking at a vaccum leak or even looking at a faulty O2 sensor.If the O2 sensor in within specs i would soak it in vinegar over night and then blow it out with compressed air in the morning nad let it dry out before reinstalling.
    (KRUPTOR)VN BT1 5L TTB's,MANUAL,LSD
  1. How sweet is this!!!!
    By nicko in forum The Pub
    Last Post: 16-12-2007, 09:54 AM
  2. sweet fiat
    By commyvx in forum The Pub
    Last Post: 19-03-2007, 05:32 PM
  3. sweet as vh
    By YoungOne in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 17-10-2005, 10:51 PM
  4. sweet harmony
    By Danzilla in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-06-2005, 10:40 AM
