Results 1 to 5 of 5
Thread: Vp slipping handbrake ratchet
    vr
    Feb 2008
    Default Vp slipping handbrake ratchet
    The handbrake on a friends sedan is not holding, you put it on and the handle sometime just drops or knock it. I'm told the ratchet is warn. I checked in the handbook I've got and theres nothing in there about it, searched the posts on this site and got nowhere. What needs replacing so I can get one from the wrecker, I have not taken one apart before so I'm not certain what to look for or replace. Can anyone help?. thanks
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Could be one of three things, it will either be the toothed bracket that is worn, the spring in the handle, or the ratchet itself that has worn. You need to remove the console to get at it.
    Visit my Facebook page
    vr
    Feb 2008
    Thanks, does just pull out under the car? or do you need to do something else after removing the 2 bolts?
    thanks
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Does what just pull out? What have you undone?
    VPCalais38's Avatar
    VPCalais38 is offline VP Sleeper
    93 VP V6 Calais Series II
    Nov 2005
    Geraldton, W.A
    I had this prob on my VP.
    All it took to fix mine was to wrestle the rubber handgrip down further so the button stuck out more.
    Guessing that the rubber handgrip was stopping the button from popping out completely.
    Might not be the case with yours.
  1. B&m pro ratchet
    By pen15 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-11-2007, 07:24 AM
  2. B & M Pro Ratchet New
    By RVN 355 in forum Parts And Other Items For Sale
    Last Post: 26-08-2007, 12:57 PM
  3. Ratchet Shifter in VT/VX
    By Bungle in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-10-2006, 06:50 AM
  4. b&m pro ratchet shifter
    By brohawk in forum General
    Last Post: 03-07-2006, 11:07 PM
  5. b&m pro ratchet
    By low-304 in forum General Discussion
    Last Post: 06-05-2006, 12:52 PM
