heya all
my clutch has started to slip
can it be adjusted to stop it or new clutch fluid (where does it go???)
what are my first steps in beating this or am i gunna have to put in a new one?
done my mates about 3 weeks ago, went from slipping a little to a lot very quickly, baby it around until u can afford a new one of if u can go for a new one![]()
m3taL... for what its worth...
http://s92.photobucket.com/albums/l9...rrent=vn-3.jpg
My Ride
88' VN 3.8 5spd, Custom CAi, 2.5 High-flow zaust && Foaming Tune!!!
Turbo Manifolds and Plumbing Near completion!
Family Ride:
2007 Kia Grand Carnival Lux Model
yea once it starts slipping you know your clutch is saying bye bye... get a new one before you get stranded in the middle of an intersection lol.......
how much they worth and what sort should i get?
anything i should really know before i buy?
anything i should know before i install? my dad n i will do it, any tips?
thanks heaps people for the info, much appreciated
That depends on your driving style and car setup! - if it's just a stock motor, stock diff etc, I'd jsut recommend running a stock replacement clutch.how much they worth and what sort should i get?
Even if it's a little bit tricked up, I'd personally still run the stock clutch - think of it as a 'safeguard' against serious gearbox/diff damage, The soft factory clutch is designed to work with the gearbox and diff and can potentially save them seeing crazy forces!
And basically, if it didn't slip when you were gunning it when the clutch was good, you don't need any better!
As an indication, my 'stock' clutch (v8 diaphragm, stock otherwise) only ever slipped when doing a 3rd gear two wheel burnout @ Calder, on slicks..
Repco or any of the other mainstream car shops are a ripoff unless you have a trade discount. I'd highly recommend a shop called 'sunbury brake and clutch', which I've bought from before on eBay.. (link is to exact same clutch setup that I ran in a heavy duty application, and can't fault).anything i should really know before i buy?
Commodore vn vp vr vs Clutch Kit V6 ,Heavy Duty 88-96 - eBay Clutches, Transmission, Car Parts, Accessories, Cars, Bikes, Boats. (end time 15-Mar-08 21:27:57 AEDST)
When you're aligning the clutch plate between the pressure plate and the flywheel, if you don't have the proper tool to align it (or don't have a spare old t5 input shaft), you can align the center pretty much spot on going by the edge of the clutch/pressure plates. You can use your fingers to position the clutch plate pretty much dead on by feeling for spacing along the outside edge of the clutch/pressure plateanything i should know before i install? my dad n i will do it, any tips?
Also remember inspect the flywheel for cracks and all that kinda stuff - if it's got bulk grooves in it, you should get it machined.
When you're removing the gear shifter stick, the two allen key bolts can be a prick to remove, so get some wd40 on them and the PERFECT allen key. If you're lucky they'll come right out - otherwise you might have to cold chisel a groove in there for a screwdriver or something.
ummm.... oh and be careful with the routing of the clutch cable when you're re-assembling anything! specially if youve got extractors, just make sure you keep it clear of the zorst!
That's enough out of me! - Good luck!
DUDE
thanks so much for the info, just intime for the weekend too, just a couple of things
i have an exhaust, pod, chipped ecu and extractors, so not a stock clutch 2 buy then?
also where do i put the clutch fluid? its a v6 too by the way
thanks soooooo much again
I run a PBR? heavy duty clutch in mine, alot better than standard. Id recomend that. Cost about $250.
I ran a stock (well v8 pressure plate, but same as stock really) clutch behind a blown cooled and spooled v6, with no dramas (except for the 3rd gear burnout on slicks at the track - but that's expected)...
Up to you, I don't think you'll notice any difference between a heavy duty and a normal clutch, other than the fact that the stock clutch will be a bit more forgiving if you keep on dropping it![]()
ok cool, thanks guys, but where does the fluid go?
i cant find anywhere in the engine bay that it goes
Its only on autos that it has a top up pipe and dipstick. The box has a filler hole and a drain hole on the side. Obviously the filler is the top one and drain is the bottom one. Is on the drivers side.
thanks heaps bro
now i feel like a dumbass, oh well ask questions and learn is my motto
thanks again guys, will keep u posted, so i just put gearbox oil in there? not clutch fluid?
whats this i hear about a floating clutch
bloke mentioned it and could be around $2200
WTF
how come so expensive and wont a normal clutch do?
NEED HELP ASAP
VT has an expensive clutch. VN is just the normal garden variety type.
so just a stocka will do the job for me?
just its slippin fairly bad now, cant adjust or anything???
just that its 250 i dont have atm
You will find that the pedal will not need to be depressed much to disengage the gearbox. No adjustment is possible when this happens, just a worn out clutch.
