Page 1 of 2 12 LastLast
Results 1 to 25 of 50
Thread: best exhaust
    bboystyles's Avatar
    bboystyles is offline chicks dig guys wit utes
    VP ute
    Sep 2007
    Perth, WA
    Default best exhaust
    hi ppls
    just wondering wat other ppl wuld say is the best sounding exhaust to get for under 2000 bucks. i have a V6 VP ute. i was thinkin sumin along the lines of a twin straight through 3", but then agen i wuldnt have a clue
    what r your suggestions?
    cheers
    STEALTHY™'s Avatar
    STEALTHY™ is offline So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    Its difficult to make a V6 sound good. The onyl one i've heard, was a Turbo Ecotec.
    A twin 3in is overkill for a stock V6 also, look at a single 2.5 at the biggest.
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
    wrx884's Avatar
    wrx884 is offline WA's ASR Rep
    VT Commodore Exec/5L VP Calais
    Mar 2006
    Being a V6 also u shouldnt b spending much more than 1500 and thats only coz u want twins straight through and bein 3" prolly wouldnt b ideal unless u plan 2 supercharge it or somthing. as stealthy said go the 2.5 u should get all that 4 around $1000 + headers
    Check out my ride in progress.... 98 VT V6, V8 Supercar kitted
    Daily toy.... 92 VP Calais 5L
    UNKNOWN's Avatar
    UNKNOWN is offline DEFECTED
    95 VR SII BT1 5 Speed
    Jan 2008
    NW Adelaide
    Even 2.5 is overkill in a stock V6, Id just get extractors, leave your standard exhaust piping but get the center muffler changed to a Lukey straight through then remove the rear resinator.
    I have this set up on mine, minus cat. And it sounds orsm!
    vnss
    Jan 2005
    s.e melb
    i wouldnt even get extractors id just get a mandrel bent 2.5 inch with a straight through mufffler in the middle and a hot dog at the end or straight thru pipe
    all this in mild steel will be under 500
    bboystyles's Avatar
    VP ute
    Sep 2007
    Perth, WA
    VP 5L Calais
    Mar 2007
    S.A
    Best V6 i ever heard had advance headers and a 2.5 inch redback system. it sounded racey as, not the shocking tin can drone noise most others make.
    bboystyles's Avatar
    VP ute
    Sep 2007
    Perth, WA
    if i do any mods to the engine will i have to end up re-doing the whole exhaust?
    STEALTHY™'s Avatar
    Jan 2005
    No, unless you change motors.
    A 3in is over the top because there is too much flow. You will lose power doing things this way. Thats just right for a V8. My Twin 2.5 is overkill for my stock V8, but i don't care about power, i want decent sound!
    cheers sexy
    bboystyles's Avatar
    VP ute
    Sep 2007
    Perth, WA
    STEALTHY™'s Avatar
    Jan 2005
    Twin 2in maybe, if they make an exhaust that small.
    I don't see any benefit from having a twin system tho
    cheers sexy
  12. Default
    what kind of mods are planned. 3 inch is overkill because your car will never be working hard/fast enough to utilise the whole 3inch diameter, so it's a waste. and you're talking about dual 3 inch so that's crazy! it won't make it sound better either. the only time you need dual 3 inch is if you were boosting it and even then you'd be running crazy boost. and so the answer is no, you don't have to do the whole exhaust if you do engine mods. get a single 2.5 inch cat back with straight through muffler and no resonator, $600 maximum. get a good brand muffler like lukey. seeing as you've got $2000 i'd definitely get pacemaker/lukey headers and maybe a hi-flow cat as well. couple that with a CAI and custom tune (talk to greenfoam on the forums) with the left over money and you've got a mean machine. still should be way under $2000 for all that!
    Quote Originally Posted by zai View Post
    I am not sutpid
    bboystyles's Avatar
    VP ute
    Sep 2007
    Perth, WA
    ah ok cheers. i jus wanted a twin coz they look so much better than a single.
    STEALTHY™'s Avatar
    Jan 2005
    You can get a twin tip made up easily enough. Either fake or working. Having a ute, you have the benefit of a tank not in the way. Whatever exhaust shop you go to can help make this up for you.
    cheers sexy
  15. #15
    bboystyles's Avatar
    VP ute
    Sep 2007
    Perth, WA
  16. #16
    Oct 2007
    guys quik question
    which exhaust shops deal with lukey? i am in melbourne keilor downs area.
  17. #17
    VP Executive R-spec
    Jan 2005
    Quote Originally Posted by STEALTHY View Post
    Twin systems make more power, that's something ?
  18. #18
    STEALTHY™'s Avatar
    Jan 2005
    on a V8 yes, on a V6?
    cheers sexy
  19. #19
    VP Executive R-spec
    Jan 2005
    Yep on a V6 too because you can get a X pipe in there for some extra scavenging. Still not worth the cost on a V6, most things aren't. Why have 115 rwkw for 3 grand when you can have 105 for free, that's what I say
  20. #20
    m3taL's Avatar
    m3taL is offline For what its worth.....
    88` S1 VN, 5spd & 94' VR Wagon
    Aug 2006
    Bendigo, Vic
    I run a 2.5i Redback Catback sys Single Muffler cheap but effective. (on my v6)
    No tip or Resinator just straight out the back (tips make them sound pox)
    i had this system on before i put the pacemakers on and it sounds pretty much the same now as it did then. the headers just made it bark a little more.
    On my last vn (s1 v6) i ran a genie turbo Staineless 2.5i single muffler system and it sounded pretty much the same as thus one. but cost like 300 more.
    m3taL... for what its worth...
    http://s92.photobucket.com/albums/l9...rrent=vn-3.jpg
    My Ride
    88' VN 3.8 5spd, Custom CAi, 2.5 High-flow zaust && Foaming Tune!!!
    Turbo Manifolds and Plumbing Near completion!
    Family Ride:
    2007 Kia Grand Carnival Lux Model
  21. #21
    STEALTHY™'s Avatar
    Jan 2005
    Quote Originally Posted by greenfoam View Post
    I would've thought any 'gain' would be lost from backpressure.
    cheers sexy
  22. #22
    VP Executive R-spec
    Jan 2005
    backpressure is a old grandmas tale man. I swear it was invented by exhaust shops that have no clue so they can be lazy and sell you a **** exahust:P
  23. #23
    Oct 2007
    guys i have a vn v6 manual which pacemaker extractors should i go for.
    1 ⅝" or the 1 ˝" ? i have cold air and v8 throtle body. i also just got 2.5i cat bak lukey system.
    thx
  24. #24
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    Pacemaker headers with a 2.5" system with one muffler and a standard cat. I wouldn't bother with anything else.
  25. #25
    Oct 2007
    yes i have that setup just unsure wot size extractors i should go?? 1 5/8 -41mm or 1 1/2 - 37 mm ithnk ?
  1. Wanted VS V8 exhaust / HSV exhaust / Merge pipe
    By prettyboringbloke in forum Swap / Wanted to Buy / Trade
    Last Post: 21-02-2008, 03:06 PM
  2. List Of Exhaust Quotes no it's not another exhaust question:)
    By Thomas1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-11-2006, 08:57 AM
  3. VT Exhaust (not jst another exhaust thread)
    By raZel in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-09-2006, 03:50 PM
  4. vn exhaust
    By fruity in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-06-2006, 11:11 PM
