Results 1 to 3 of 3
Thread: microtec help
    vq rat's Avatar
    vq rat is offline vq rat
    vn bt1 burnout weapon
    Mar 2006
    hamilton vic
    Default microtec help
    I have just finished putting the new motor in my vn it runs a lt8 microtec system is there a safe tune inbuilt init to run it on as it runs but very rich i have the hand held with all the info on it but i wont a better tune to run it in a bit before i take it to be tune by a pro it has a 288 crane cam init 1:65 roller rockers, come twin throttle its running 40psi fuel pressure all help would great
    vp vactioner wagon
    Mar 2006
    as far as i know they have a base map with comes with the computer to suit ur engine when you order it, base map holds back your timing and makes it run very rich, i know this as my rx3 has a microtech. if your after a awsome tune go to Maztech and they will sort you out.
    cheers
    georgeonboost's Avatar
    georgeonboost is offline clutch it!
    slammed VP EXEC
    Jun 2005
    Melb SE Suburbs
    Quote Originally Posted by VPWAGZ View Post
    agreed, definately go to maztech....they know exactly what to do with microtech's.
