Results 1 to 2 of 2
Thread: Fuel Pump Problem?
    VY Clubsport
    Apr 2006
    Default Fuel Pump Problem?
    You know how when you turn the key and the fuel pump primes and you hear a whirring sound for a couple seconds and it stops? well I wait for the whirring to stop and then I start the car. It runs for about 5 seconds and then stalls. When I start it a second time it runs fine, but while I'm driving I can hear the fuel pump whirring loudly sometimes. Then when I turn the ignition off the fuel pump goes for about 7 seconds after the engine is completely off. The car practically floods itself while i'm driving, and I have practically no fuel economy. All the fuel lines are fine, and my injectors are good too. Would it be a blocked or faulty fuel pump? or a sensor?
    The car is completely standard minus a Police ECU, it usually idles around 800rpm but usually doesnt stall.
    m3taL's Avatar
    m3taL is offline For what its worth.....
    88` S1 VN, 5spd & 94' VR Wagon
    Aug 2006
    Bendigo, Vic
    Ok dont hold me to this, but i think the Fuel pump has some kind of Bypass on the Oil pressure switch so if the Fuse blows or relay cacks itself it continues to run. i'd be checking fuses and relays.
    but if it is noisy i'd say she;s on her way out iv had 3 vns now and done a fuel pump in all 3.
    1st one just died and never came back on
    2nd one failed a few times leading me a stray on to what the problem is then died
    3rd was noisy but didnt seem to have the pressure to run the car.
    i'd change the fuel filter as well just to make sure its not blocked and causing friction.
    hope this helps
    m3taL... for what its worth...
    http://s92.photobucket.com/albums/l9...rrent=vn-3.jpg
    My Ride
    88' VN 3.8 5spd, Custom CAi, 2.5 High-flow zaust && Foaming Tune!!!
    Turbo Manifolds and Plumbing Near completion!
    Family Ride:
    2007 Kia Grand Carnival Lux Model
  1. Vr Fuel Pump Problem help
    By [QW-11-KE] in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-05-2012, 06:19 PM
  2. fuel pump priming problem
    By CSL in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-08-2006, 11:57 PM
  3. fuel pump/sender unit re-installation problem
    By sparra_gump in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-05-2006, 05:01 PM
  4. problem with fuel pump or tank
    By SaGe in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-05-2006, 02:19 PM
  5. VX Excex fuel pump /LPG problem
    By tiges1 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-01-2006, 06:56 PM
