Results 1 to 16 of 16
Thread: Level 2 cluster question
    JD
    JD is offline Donating Member
    VS Berlina
    Aug 2006
    Deep South, SA
    Default Level 2 cluster question
    I'm thinking about getting a Level 2 cluster for the VP because i want a tacho ( having a manual without it is annoying ) but is the wiring there for it to work i.e. can i bolt it in and the tacho will work or do i need some bits and pieces?
    We got rep back, yaaay!
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    Man, learn to do searches, seriously.... this has been covered so much.
    Yes. Straight swap.
    *Closed*
    aZk.
    Cobez's Avatar
    Cobez is offline LS-EXUAL
    2004 S2 VY SS Ute
    Feb 2007
    No wiring needed, It has 3 plugs on the back that slot straight into the dash where the cluster sits. Seriously takes about 10 minutes all up to take the old one out slot the new one in.
    The hard part is slotting all the little looms back into the dash facia surround (your parker light switch, emergency lights, cruise control etc) Even that couldn't be easier.
    Quote Originally Posted by wikky
    As already stated, mate you're an absolute gherkin strummer.
    STEALTHY™'s Avatar
    STEALTHY™ is offline So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    make sure you get one from a car with the same motor as yours. i think the tacho settings are out if you use a V8 cluster on a V6
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    Quote Originally Posted by STEALTHY View Post
    As STEALTHY said.
    Also make sure it is a VN/VP cluster and that the circuitry on the back is the same colour as your current cluster. Some are green, some are blue.
    Black VN MANUAL
    Feb 2007
    Top of Vic
    I have a L2 cluster in a Vn S1 and put 9l in it and it hardly moved didnt go over the red line could this be a V8 cluster lol ( because of the big droptank )
    ~ VN POWER ~ Click the scales
    1991_Vn2nV's Avatar
    Mar 2006
    Quote Originally Posted by Bz Kn33z View Post
    There is a switch on the back of the cluster for fuel tank size (V6-V8). Well, in the level 3 there is anyway. But 9L is not much.. Still another 54L before you fill the tank
    Black VN MANUAL
    Feb 2007
    Top of Vic
    JD
    VS Berlina
    Aug 2006
    Deep South, SA
    Oct 2006
    Quote Originally Posted by 1991_Vn2nV View Post
    As STEALTHY said.
    different colours didnt make a difference with mine as i changed from a blue one to a green one and dont have any probs
    STEALTHY™'s Avatar
    Jan 2005
    I thought he was saying that one colour is VN/P, and the other colour is VR/S.
    Either way, DON'T use a VR/S clusted in a VN/P. However, you can use the gauges, taking them out of a VR/S dah, and putting it into you VN/P dash (Speedo, tacho etc)
    cheers sexy
    JD
    VS Berlina
    Aug 2006
    Deep South, SA
    cheers stealthy, i'm heading up to upullit tomorrow, hopefully i can find one.
    STEALTHY™'s Avatar
    Jan 2005
    You know you can use a level 3 cluster.
    Without doing the wiring, the screens wont display anything, and obviously k's wont click over, but the gauges will still work. Just if you like the look of them better.
    Same still applies, only VN/P clusters, and V6-V6 etc.
    cheers sexy
    1991_Vn2nV's Avatar
    Mar 2006
    Quote Originally Posted by jas89 View Post
    Perhaps its only level 3 that matters for the 4th plug?
  15. #15
    Oct 2006
    alls i know is that the one i have now is a green backing and the one i got out of it (original) was a blue......however i think the one i have now is out of a lexan so maybe they are green? and yeh never mix vr/s ones with vn/p....big mistake (never done it but herd it too many times to be trying) also i have about 5 clusters (series one vn) in the shed and some are green and some are blue....but yeh pretty sure that the vr/vs are only green not blue?
  16. #16
    1991_Vn2nV's Avatar
    Mar 2006
    I think VR/VS are both also. When I bought my level 3 dash the guy asked what year and I said 91 so he gave me a green backed cluster. I removed my cluster from my car which was blue and the green cluster wouldnt work so I had to take it back. He happily swapped it over as he thought mine should have been blue...He thought earlier VN's were green, later blue. Im not sure if there is any pattern to it though.
  1. Installing A Vr Instrument Cluster Into A Level 1 Cluster Vn Exec
    By badly_drawn_boy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-07-2011, 02:41 PM
  2. replacing level 2 cluster with level 3
    By Matt_vp in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-01-2010, 09:30 PM
  3. Level 1 dash cluster to level 3
    By SSbeast in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-10-2006, 06:28 PM
  4. Replacing level 2 cluster with level 3.
    By madmick in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-03-2006, 11:18 PM
  5. VS Level 1 to Level 3 Cluster Upgrade
    By Luv holdens guy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-02-2006, 01:28 PM
