dont think they do.. could be wrong tho.
i know they dont fit the other way around, but would IRS VP springs fit into a live axle VN? (i have heard rumours that they do) cause i can get a full set of superlows from a vp from a mate for $20.
cheers lads.
~ VN POWER ~ Click the scales
if they do it aint gonna be a straight swap.......pretty sure they wont but as Bz Kn33z said i also could be wrong....
Different height, shape and dia. All they have in common is they are both coil springs.
Reaper
aight thanks lads, appreciated.
if anyone knows someone who wants to swap irs vp rear superlows for ultralow/superlow rear vn springs then give us a yell.
edit: the fronts will fit right... ?
Fronts are the same. Just make sure they are for a 6 cyl. V8's use a higher spring rate.
Reaper
Somebody on here reckons they have IRS rears on a live axle, can't remember who it was though. I suspect they think they have IRS springs, but they are really live axle ones as the IRS springs get narrower at the top and bottom, but live axle retain the same diameter through the whole spring.
They are probably off the HQ-WB series Holdens then, not Commodore.
yeah they most probably are off that series holden. they were on my commo when i got it, the extra track on the fronts does make it handle better though.
