Results 1 to 11 of 11
Thread: knock knock bloody knock
    petesvns Guest
    Default knock knock bloody knock
    hi i got a late 91 VN S series 1 its has the V8 brakes FE2 suspension and stuff like that now everytime i go over a decent bump the drivers side knocks now is there anyway of checking anything befor i take it to a suspension guy and he charges me $90 just to have a look at it and turn out to be a bush i know its not my bearings i just replaced them so any ideas anyone?????????
    rattattack1313 Guest
    Cool clunking...
    I would go to another suspension place..... they shouldnt charge for looking......its in the front?????tie rod end might need tightening...... just get a mate around, u lie down under the front, and get ure mate to push it up & down....(bonnet up might help him hear where it is coming from).....then take it to the mechanic.........
    VpV6 is offline Banned
    VP II Executive
    Feb 2005
    Check the lower ball joints, and all the control arm / antisway bushes. Just grab hold of them and rock (should hear the clonk) or get a mate to bounce up and down around the bonnet while you look.
    VP Executive
    Feb 2004
    Check the strut bearing caps.
    Has this started happening after you did stuff the the car (brake upgrade etc.) or has it just started on its own ?
    Bad Benny
    petesvns Guest
    ok iv checked the sway bar its fine and all bushes are fine i got a mate to jump on the bonnet (not literly lol ) and it only seems to do it when ya driving not while parked and another thing thats stared to happen is when ya reversing out or turning the wheel more than one turn while goin like 2kph for excample it makes a clicking noise underneath the car any ideas ???? :b:
    vn s-pac v6 series-2, vp v6, vr berlina v6
    Sep 2004
    Quote Originally Posted by petesvns
    i have similar although no clicking. but if i do a sharp slow turn particuly over a bump or ditch when i start to straighten up i get a knock.
    petesvns Guest
    ok iv found what the clicking noise is its the steering rod that goes into the powerstreering arms i can riggle it a bit any idea what price im looking at for replacement?? and knock is still there after iv checked everything even shockie i think its posesed
    VSII Acclaim Bitsa
    Jun 2004
    Mine used to do that so I replaced the rack ends which were buggered, and had everything up the front end tightened. Knocking stopped and the car felt much better for it.
    Bec
    petesvns Guest
    ok iv takin it to a mechanic we went for a drive it made no noise what so ever soon as i got out of the drive way it started again checked if it was a weight issue put one of me mate in the car kept doin it and iv narrowed it down to 2 thing its ither the shockie or the flamin cat i hit the other month has come back to haunt me so it has me very confused.
    as to "Has this started happening after you did stuff the the car (brake upgrade etc.) or has it just started on its own ?" question no the s pac came standard with V8 brakes and V8 brake booster as well as FE2 suspension so i havnt touched it yet.
    Egrep Guest
    Hey, I had a similar knock sound from engine bay, more prevalent when I hit bumps etc, turned out the rubber bush the bonnet sits on adj to hinge was stuffed and the bonnet was bouncing and knocking. Quick check grab bonnet near windscreen at corners and see if it will move, try drivers and passenger side. You never know.
    Egrep.
    petesvns Guest
    no mate i can hear its coming from the frount drivers side wheel area its not me bonnet but thanks anyway
  1. HELP.... Top end knock!!
    By bigwang in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-05-2006, 06:42 PM
  2. wheel knock
    By smooth vl in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-12-2005, 07:36 AM
  3. WTB: VR knock sensor
    By 2_SeeK_U in forum Swap / Wanted to Buy / Trade
    Last Post: 13-12-2005, 12:25 PM
  4. knock knock, whos there?
    By blunt in forum Jokes/Humour
    Last Post: 03-11-2005, 06:03 PM
  5. Knock
    By .::Crocodile Hunter::. in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-01-2004, 11:50 PM
