Results 1 to 5 of 5
Thread: VN Wiper motor and Rails
    VH Wagon SLX 253
    Nov 2004
    Southern Highlands
    Default VN Wiper motor and Rails
    Has anyone ever changed the wiper motor and rails in there VN ? Is it a hard job to do ?
    Reason being the driver side wiper seems to come off whatever its attached to and it bounces aroudn against the windscreen when its on.
    I figured it be cheaper to fix myself than get holden to do it
    crazyspoon05's Avatar
    crazyspoon05 is offline Penguin Whisperer
    The 'Bizta' VNVPVR Wagz
    May 2006
    It's not overly hard, just make sure you set the wipers to the correct park setting before putting everything back together correctly otherwise it gets annoying having to undo the nuts, remove the arms, take the plastic back off, etc to reset the park angle
    If ignorance is bliss why aren't there more happy people around ?
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    Quote Originally Posted by Secki View Post
    Its only 3 nuts and a plug. So its quite easy to do.
    Sounds like you've threaded the wiper arm.
    VH Wagon SLX 253
    Nov 2004
    Southern Highlands
    If you grab the wiper it moves in and out and sideways im hoping somethigns just slipped off
    May 2006
    What 1991_Vn2nV said
    Stripped thread so will need to replace the entire assembly
  1. Wiper Motor..
    By 1991_Vn2nV in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-02-2008, 09:56 AM
  2. vc wiper motor
    By -vkhg in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 31-08-2007, 11:21 PM
  3. rear wiper motor
    By shae in forum Electrical Wiring / Questions
    Last Post: 20-06-2006, 02:56 PM
  4. Windscreen wiper motor
    By huwbacca in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-06-2006, 05:17 PM
  5. Wiper Motor Stuffed?
    By fitzy2005 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-04-2006, 10:17 PM
