Results 1 to 22 of 22
Thread: Pogo Stick Effect in Front End
    VN Series 2, FG R6 Ute
    Aug 2007
    S/E Suburbs
    Default Pogo Stick Effect in Front End
    Hey all, My VN is ****ing me off at the moment. The front shocks are crap. They make the car bounce all over the road, even on the slightist bump. There like pogo sticks. Car is lowered with king springs superlows (KHPR - 22SL) and Pedders Comfort Gas shocks (PE- 8731) Parts where put in by my mechanic, who is flat out until after easter. Shocks where installed halfway through November last year.
    What can i do???
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    Aug 2007
    S/E Suburbs
    What springs/shocks have you got???
    Also just went for a drive WITHOUT playing any music! and i can hear one of the shocks making a noise, when i got over a bump.
    May 2005
    .....SE Burbs
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    what does it do when you do the bounce test in the driveway?
    Body by Holden, Soul by Brock
    the Legend will live forever
    May 2005
    .....SE Burbs
    Aug 2007
    S/E Suburbs
    same here. Found out it was the left shock making the noise. Sounds like is rattling and wants to shake itself loose when i go over a bump. Also just took the wheel off and i can grab the dust seal? is that what it is? and lift it all the way up.
    I'm thinking it's not installed right.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Make sure the cap that holds the cartridge in is tight.
    What size tyres are you running and what pressure is in them?
    Visit my Facebook page
    Aug 2007
    S/E Suburbs
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Huh?? Is that the thing on top of the strut tower?
    Tyres are 235/45 R17 inflated to about 50Psi
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    No, there is a big nut looking thing in the top of the tube where the shaft of the strut goes in and out. Make sure that is tight.
    Try dropping your tyre pressure down to 38 psi. 50 psi on a 45 profile is too high I reckon.
    Aug 2007
    S/E Suburbs
    Just checked, the nut thing is tight. I'm thinking i might go to pedders and get a shock absorber test done.
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Did you check it with the suspension hanging? You may want to support the body and put the jack under the control arm and lift it a little taking the pressure off it. With it hanging, the full force of the spring is on it, and it may not move. Tighten the top nut in the engine bay as well.
    Aug 2007
    S/E Suburbs
    Ok. I just got my car back. Mechanic ran it down to pedders so i didn't have to pay for the shock absorber test.
    Pedders reckon that the left hand shock is buggered and needs replacing. They think it may have leaked. They also want to replace the right side shock for safety.
    These shocks are about 4 months old. This is crap i want them replaced free of charge by my mechanic who has stuffed something somewhere.
    Haven't disscussed this with my mechanic as he wasn't there when i picked my car up.
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    The shock should be under warranty. Check with your mechanic as to his labour warranty, usually it is only 3 months. You may have to pay for the labour. Or you could take it out yourself and take it back.
  15. #15
    Dan355's Avatar
    Dan355 is offline Go THE SS's
    Street Legal 355ci VN SS - Daily: VP SS
    May 2006
    Are those shocks shortened for lowered vehicles? I know that if you run standard shocks on a lowered car they'l flog out pretty quickly it can also cause issues with springs not trapping properly.
  16. #16
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    No they don't. The only reason shortened shocks are used is to trap the spring.
  17. #17
    Aug 2007
    S/E Suburbs
    Yeah there pedders shortened shocks. Part number is in my first post. Hopefully getting them replaced sometime next week. I'll let you know how it goes.
  18. #18
    5sp VN Executive1988, VX SS 6sp
    Apr 2006
    canberra
    When i 1st got front of my car lowered same thing happened after about 5 months or something. I just took car back and told him the prob and he fixed it right away free of charge
    Australia. Love it or leave it
  19. #19
    Aug 2007
    S/E Suburbs
    Bit of an update, car is having its front shocks replaced with the really heavy duty shorted shockers the pedders do. It better fix the problem or im going to sell the bloody thing. I've had enough. Also now the lower bushes need replacing because of the crappy shocks.
    For those with this problem, simply your springs are to hard and your shocks are too soft.
  20. #20
    Aug 2007
    S/E Suburbs
    Hey, got the car back last nite. Drives sooooo much better now. It now has the trakryder shocks from pedders in it. Also the lower control arms where replaced as well. Not the lower bushes.
    Hopefully this helps out other people.
  21. #21
    VP exe
    Sep 2007
    replaced the lower control arm ?
    your bushes must have been shot, cant see any other reason for them doing that.
    but if they replaced it with new bushes it would feel a lot firmer now and would compliment the new shocks
    Gone Fishing...
  22. #22
    Aug 2007
    S/E Suburbs
    Quote Originally Posted by Just_a_stocker View Post
    Yeah they where stuffed. As they are just hanging there, they where replaced while the new shocks were fitted.
  1. Victorian P Plate Laws - Effect. July '08
    By Frandy in forum The Pub
    Last Post: 18-10-2007, 10:33 AM
  2. Will leaky exhaust effect fuel economy?
    By Marcus G in forum VL Holden Commodore (1986 - 1988)
    Last Post: 07-12-2006, 01:19 PM
  3. effect of thermostat on fuel use
    By michaelw in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-10-2005, 10:38 PM
  4. Effect of ethanol in fuel
    By Minotaur in forum VL Holden Commodore (1986 - 1988)
    Last Post: 13-09-2005, 12:19 PM
  5. Stick It To Em Day
    By Shounak in forum General
    Last Post: 03-09-2005, 03:53 PM
