Results 1 to 4 of 4
Thread: Poor Fuel Consumption VP V6 in Triton
    Dec 2007
    Question Poor Fuel Consumption VP V6 in Triton
    Hi, About 6 months ago i replaced the 2.6 litre 4 clyinder in my 2wd Mitsubishi Trition with a VP V6 engine/auto. Swap was dead simple. I realise the fuel economy would not be as good as the Commodre due to running the standard 4.2 diff. (2500rpm / 100ks) I am getting around 18L per 100k. Which is 50/50 with highway and town driving taking it very easy. I have changed the Coil Pack and DFI Module, New leads, Crank angle sensor, Oxy sensor,Map sensor, new air cleaner element and have run injector cleaner with no effect on reducing economy. Apart from Fuel economy the things starts and runs great. Maybe this is as good as its going to get. Any Ideas?
    VPCalais38's Avatar
    VPCalais38 is offline VP Sleeper
    93 VP V6 Calais Series II
    Nov 2005
    Geraldton, W.A
    I average 12.9L/100km in my calais.
    Used to average 17.8 before I changed the oxygen sensor.
    As you have already done that it may be something else.
    Can you get fault codes out of the computer?
    Dec 2007
    thanks for your reply VPCalais38. I have fixed it by replacing the Coolant Temp sensor.
    KRUPTD is offline VN BT1 5L
    VN BT1 5L,5spd,LSD
    May 2007
    Griffith, N.S.W
    I would suggest replacement of diff gears so the engine would rev lower,this will help dramatically in fuel consumption.Also have a good air intake setup to allow nice cool air into the engine.I used to have a hilux 2wd single cab with a worked 308 2000rpm stall trimatic shift kitted auto and 3.1 lsd borg warner diff and on a trip i would average around 15L per 100km and then around town would get up to 22L per 100km.
    (KRUPTOR)VN BT1 5L TTB's,MANUAL,LSD
  1. Fuel Pressure Regulator - Poor fuel consumtion
    By Chuckster in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-11-2008, 03:49 PM
  2. VS Misfire at idle on hot days + poor fuel consumption
    By AnthsVSLexcen in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-01-2008, 07:51 AM
  3. VL poor fuel economy-check this
    By krooz in forum VL Holden Commodore (1986 - 1988)
    Last Post: 13-02-2006, 02:07 AM
  4. poor fuel economy
    By VS1Tonner in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-09-2005, 09:11 AM
  5. Poor fuel Consumption
    By AMAGDN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-08-2005, 02:20 PM
