Results 1 to 17 of 17
Thread: oxygen sensor questions..
    padrickz88's Avatar
    padrickz88 is offline Rick =]
    VN V6, nothing special
    Dec 2005
    sunshine, melbourne
    Default oxygen sensor questions..
    ok so my oxygen sensor has gone to a better place.... and i need a new one, so here is the questions
    1. if i was happen to get hold of a L67 oxygen sensor, would it be a direct swap? (i read somewhere that it is but id rather confirm with you guys before i go spending money)
    2. roughly what would be the price of one? the supercharged and the stock replacement?
    sorry if this seems like a n00b question but i couldn't find it anywhere and thought if it's a direct replacement, then why not put something better in
    thanks alot
    Tom_1569's Avatar
    Tom_1569 is offline Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    New ones stock replacement is about 30-40 bux. Theirs to different types, a single wire and a double wire. Make sure you get the correct one.
    Quote Originally Posted by alien View Post
    I have been hit by oil badly once while in Army uniform on a massive roundabout that doesn't exist anymore. Spun 180 degrees to face oncoming traffic.
    KiwiHoldenDriver is offline Loud, proud Kiwi
    VT Olympic Spec V6
    Jan 2008
    Auckland, New Zealand
    I recently had my exhaust replaced. One issue was that the oxy sensor was not fitted in the exhaust system. Should I get one fitted? I don't have any issue with power from the V6
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    Quote Originally Posted by padrickz88 View Post
    thanks alot
    It will not be a direct swap as you have a series 1 VN which means you'd have a 1 wire oxygen sensor. Series 2 onwards had 2 wire oxygen sensors. (VS might have been different again anyway but were atleast 2 wire).
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    VS have 4 wire O2 sensors so i would assume that the L67 has these also.
    if you have a S1 VN you would need the single wire as mentioned above. however you can fit a 2 wire if you wish, just wire the extra wire to earth (block or chassis), should in theory give a better signal to the ecu (there is a reason they fitted 2 wire sensors to later models)
    Quote Originally Posted by KiwiHoldenDriver View Post
    you should. you may not have lost any power but it will effect your economy
    Body by Holden, Soul by Brock
    the Legend will live forever
    VS 355 Turbo, VN Calais 5L, VE SII SV6 Wag, Mirage
    Aug 2006
    Adelaide, SA
    Yeah i'm using a 2 wire one in my VN which had a 1 wire one to start with. i had a brand new 2 wire one laying here which i didnt want to waste. all you have to do is wire the black wire to earth.
    padrickz88's Avatar
    Dec 2005
    sunshine, melbourne
    ahh nice will do then... thanks for the answers people
    ill get my mate to get a price on a 2wire o2 sensor from his work.... thanks again...
    Aug 2006
    Adelaide, SA
    22 wire ones are cheaper than the 1 wire ones! so i dont see the point when a 2 wire will do the job!
    VN Executive
    Apr 2007
    Wellington, New Zealand
    Aug 2006
    Adelaide, SA
    In theory yes. 2 wire has its own earth. 1 wire earths through the extractors / block etc.. which all heats up. heat = resistance in electronics.
    Apr 2006
    Auckland NZ
    Quote Originally Posted by Anthraxnz View Post
    In Summation
    The 2 wire ones are better than the 1 wire ones?
    YES. why otherwise would holden fit em if they weren't better? as i mentioned above. all sensors need a good clean earth, that way they provide the best consistant signal to the ecu. if you have poor earthing it's going to provide a erratic signal to the ecu as the resistance changes/fluctuates . this is true for any sensor fitted to the engine
    1991_Vn2nV's Avatar
    Mar 2006
    Quote Originally Posted by PREDATR View Post
    Are you sure? The 1 wire o2 sensors were cheaper than the 2 wire ones at Repco, Holdens may be different I guess?
    Aug 2006
    Adelaide, SA
    lukas pukas's Avatar
    lukas pukas is offline Bukake, better than cream
    RS Liberty/KTM 250sxf
    Aug 2006
  15. #15
    1991_Vn2nV's Avatar
    Mar 2006
  16. #16
    Aug 2006
  17. #17
    Apr 2006
    Auckland NZ
    Quote Originally Posted by lukas pukas View Post
    awesome, always thought there might be 2 cause of the v configuration
    VS V6 onwards have 2
  1. oxygen sensor
    By SSbeast in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-04-2007, 01:36 PM
  2. which oxygen sensor do i need
    By rob_phill in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-07-2006, 09:31 AM
  3. oxygen sensor
    By ab56452001 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-07-2006, 04:33 PM
  4. oxygen sensor
    Last Post: 22-06-2006, 01:30 PM
  5. Oxygen sensor
    By HOTVR5L in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-04-2005, 02:12 PM
