Results 1 to 5 of 5
Thread: Cooling question
    KiwiHoldenDriver is offline Loud, proud Kiwi
    VT Olympic Spec V6
    Jan 2008
    Auckland, New Zealand
    Default Cooling question
    I need to replace the radiator on my auto V6 VP. I was wondering if it is better to get a VP radiator for a manual and fit a seperate transmission fluid cooler. If so, should I put the transmission cooler in front of the water cooler?
    m3taL's Avatar
    m3taL is offline For what its worth.....
    88` S1 VN, 5spd & 94' VR Wagon
    Aug 2006
    Bendigo, Vic
    you will find that all rad's these days are "Auto" meaning they have the cooler in them but you don't nesseraly need it if you have a manual.
    i recommend using the STD rad cooler for your car if it is a std box on a std engine as its costs no more and putting a cooler on a std setup will give you no gain... if you wish to use a cooler put it in series with your rad cooler so it runs out of the box into the rad cooler into the A/Mkt Cooler and back to the auto.
    m3taL... for what its worth...
    http://s92.photobucket.com/albums/l9...rrent=vn-3.jpg
    My Ride
    88' VN 3.8 5spd, Custom CAi, 2.5 High-flow zaust && Foaming Tune!!!
    Turbo Manifolds and Plumbing Near completion!
    Family Ride:
    2007 Kia Grand Carnival Lux Model
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    the best place for a external trans cooler is infront of the radiator.
    Body by Holden, Soul by Brock
    the Legend will live forever
    VT Olympic Spec V6
    Jan 2008
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Yeah, what they said. Run the trans fluid through the radiator, and THEN through an aftermarket cooler. If you could be bothered, mount the after market cooler down the bottom of your front bar, to the side, away from the radiator. Allows more airflow to the radiator on hot days.
    Also, if you have the extra dosh, invest in a VS V8 radiator. Thicker core, but still alloy, and the V6 thermo fan bolts right up onto them That's what I'm running.
    The 1972 HQ Kingswood
  1. Oil Cooling?
    By Goon in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 19-12-2006, 01:31 AM
  2. VS air con not cooling.
    By shmity in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-12-2005, 07:46 AM
  3. Amp Cooling
    By VY2ENJOY in forum Car Audio
    Last Post: 22-10-2005, 12:54 AM
  4. vn s1 cooling
    By fatvgute in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-07-2005, 11:24 PM
