Results 1 to 2 of 2
Thread: vn heads
    vn wagon
    Sep 2007
    aldgate sa
    Default vn heads
    will vn s1 heads fit vp s2 motor. also what are fe2 springs.
    VR Berlina wagon
    Oct 2005
    Smile Head swapping
    Yes they will fit, but need the PCV holes drilled before you fit them...
    The PCV hole is (from memory?) about a 5/8th hole - you can work out where it goes by positioning a new inlet manifold gasket on the head before drilling.
    FE2 is Holdens name for the optional suspension upgrade that some of the vehicles get (slightly lower ride height and slightly stiffer).
  1. 304 Heads
    By VSL05L in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-02-2007, 09:05 AM
  2. 308 heads
    By immortality in forum Yella Terra
    Last Post: 11-02-2007, 08:31 PM
  3. v6 heads
    By Calais_5sp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-01-2007, 06:21 PM
  4. hay rev heads
    By pookie_1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-10-2005, 05:08 PM
  5. New Key Heads
    By Schooner in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-10-2005, 11:58 PM
