Results 1 to 17 of 17
Thread: How to tell if my rings are worn?
    Jun 2005
    Default How to tell if my rings are worn?
    Im trying to diagnose the problem with my engine. My last compression test pulled some bad results. 1 cylinder was fine at 150psi, 4 were average at 120psi, and 1 was bad at 90psi. My two reasons for this are either blown headgaskets from running too lean under boost, or worn rings. I also think the inlet manifold gasket is in need of replacing too.
    Basically, I want to know how I can diagnose between the headgaskets and rings without having to take the engine apart just yet? The engine runs fine, just a bit sluggish at times, uses a little too much fuel, doesnt idle well on warm starts. Apart from that, it seems fine.
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    Quote Originally Posted by stocky View Post
    Head gaskets will usually yeild differnet results.
    H/Gaskets have lower compression in 2 adjcent cyclinders... ie. 2 and 4 or 1 and 3. Best bet is to redo the compression test and add a table spoon of oil to the lower comression cycilders. If they increase, you have worn rings. If they dont, you have sticky valves. If they increase dramatically, again, valves.
    Do you have any other symptoms to indicate head gasket? oil in water? Water in exhaust? overheating? There all potentional head problems but also indicate worn intake manifold gasket issues.
    Step One: redo compression test.. add oil to check.
    Step Two: Strip manifold and replace gasket on the intake. Cost about $50 and about 6hours of non stop work if youve never done it before.
    Sounds like you have ring issues... 90psi is really really low.. you may completly loose compression in it soon.
    aZk.
    Jun 2005
    looks like i might not bother at all. may have another good condition v6 ready to go in hopefully soon.
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    Jun 2005
    Quote Originally Posted by Mack View Post
    Cars breaking down hey stock block? And you were picking on my car
    hey at least mine starts
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    pow3rslave's Avatar
    pow3rslave is offline DoNothing Member
    VP 5.0L
    Oct 2005
    eastern subs, vic
    just out of interest, what's it cost to get rings replaced?
    when i got the cam in they said it'd probably make me need new rings sometime soon.
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    Quote Originally Posted by pow3rslave View Post
    that really depends on what else needs doing. if there is very little wear (not likely on a 300,000km engine) in the bore then just the cost of new rings and gaskets and a quick hone to deglaze the bores. if there is some wear in the bores you might get away with oversize rings but this is not the best option. lots of wear means gettingthe block bored out and new oversize pistons are needed.
    however if oyu pull the heads to fit new rings you have a situation where you have good ring seal with average heads. at the very least strip the heads and give em a good clean (couple hrs work) and maybe lap the valves in to make sure they have a good seal (assuming the guides aren't worn to badly)
    thats just me however, i fix things that aren't broken so says my missus anyways
    edit: just read your "ride" thread, ignore the bit about the heads, they look sweet.
    Body by Holden, Soul by Brock
    the Legend will live forever
    May 2005
    .....SE Burbs
    you can do rings from the top down? didnt think theyd come out and you'd have to pull the piston out from the bottom... hmmm...
    time for a full rebuild!
    aZk.
    ScoHar's Avatar
    ScoHar is offline Jizz in my pants
    02 VX Equipe V6
    Apr 2006
    CHCH, NZ
    Thats how you do rings from the top, otherwise you can't (or almost impossible) to use a ring compressor to squash the rings to get the piston back into the bore.
    PaRaDoX's Avatar
    PaRaDoX is online now boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    Quote Originally Posted by azkwazere View Post
    aZk.
    quite right you can only remove 2 pistons if your lucky without the heads off..
    its a engine out block apart job
    it will be headgasket, rings dont wear from detonation, headgaskets do, i had similar results in my v6... imo hes better off with a new block his bearings are probbly rooted waiting to go for a trip round the world :P and possibly give a rod the chance to see the world outside the block jail break style!
    soo, imo new motor and get a AFR test done again...
    vnv8driver is offline Banned
    304 Calais
    Aug 2007
    Up your mum
    as well as rings and headgaskets theres also possibility of worn valves, cam lobes, etc.
    if it was a headgasket theres a good chance that it will show, either water vapor/liquid out the exhaust, oil&water mixed in radiator, overheating, etc......
    VS wagon
    Dec 2007
    aZk.
    What do you classify as dramatic?
    Seems as there is a fine line between the two
    nicko's Avatar
    nicko is offline Carbon Positive - DO IT!!
    75 cruiser ute
    Sep 2007
    sa
    if you can do a crap as big as your fist, then your ring is worn!
    no longer a hoon by association - the commodore is gone
  15. #15
    304 Calais
    Aug 2007
    Up your mum
    Quote Originally Posted by nicko View Post
    hahahahaha!
  16. #16
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    talking from experiance??
  17. #17
    ScoHar's Avatar
    02 VX Equipe V6
    Apr 2006
    CHCH, NZ
    thats prob the best comment i've heard on here!!!!
  1. Sway bar rubbers worn out, but not sure, help ???
    By ac2026 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-03-2008, 10:25 PM
  2. AFM may be worn out
    By rustman in forum VL Holden Commodore (1986 - 1988)
    Last Post: 09-10-2007, 01:05 PM
  3. Need help selecting new colour for my worn out VN
    By KeEkSVP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-08-2006, 08:03 PM
  4. worn rings in V6 eco tech, replace or reco?
    By sassy_41 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-07-2006, 07:44 PM
  5. worn rings, replace or reco?
    By sassy_41 in forum V6 Development And Modification
    Last Post: 17-06-2006, 09:59 PM
