ok, 2 problems...
1....the heater vent wont change from recycle to windscreen to face etc, its stuck on floor, the dial moves but no change in vents.
2... the heater switch wont work on power level 1 or 2, will work for 3 and 4 though.
any one know what the problem could be or how to fix, I bought another switch off ebay but still the same problem. pain in the arse tryin to drive with the windscreen fogging up. cheers
I'm not sure on what vehicle you are talking about, it says your ride is a VT but you have posted in th VN-VP section.
Problem 1 could be that it is losing vacuum. Check all the vacuum hoses related to the heater particularly the thin one that goes the the rear of the intake manifold. Also check the vacuum tank.
Problem 2 sound like a fan speed resistor problem but that is usually the case when the fan only works on high speed.
MY RIDE
sorry, its a vn.
cheers for the info, I'll check the hoses, where is the vaccuum tank?
Im thinkin I couldnt be so unlucky that I purchased another switch with exactly the same faults, but stranger things have happened..lol.
I think the vacuum tank is sort of behind the bumper on the passenger's side. I think you might need to remove the plastic lining in the wheel arch to get at it.
MY RIDE
I'll get on it and get back to ya. cheers
As has been stated but with the fan speed resistor try and get a VR/VS one as they are much more reliable than the VN/VP ones and are a straight swap.
ok, cant find loose vaccuum hoses and bought another switch from a vs but still no 1 and 2 fan power, works on 3 and 4 though. changed the relay but that done nothing, any ideas???
i have the same problem works on 3 and 4 but not 1 and 2 also heater will not heat car at all. After reading this i am going to check the vaccume lines and see if any are stuffed.
I think it is the resistor under the windscreen wiper motor which is the problem, will change it next couple days see how that goes, I'll keep ya posted.
yeah i have heard that this could be the problem too. Let me no how you go.
Thanks
