I have a cat back vp standard exhaust system (non irs) that has its rear muffler removed and pipe welded on.
Do you guys reckons its worth the effort of putting it on my s1 vn from the cat back would id give a small power gain and a crappy note???![]()
vn v6 calais mock up run around,
vn v6 manual wagon parts car,
vp v6 berlina lx project car
vc 186 aussie 4 speed
vl 6cld wagon
Expect very small if anything in terms of power gains. As for the sound, I think without the rear muffler, it will drone a bit.
Cheers,
Sam
You'll get drone... that's about it. For power, you want a bigger exhaust first and foremost. 2.5" mandrel bent is the trick. At the end of the day, you can only move so much gas through a small pipe - mufflers or not.
The 1972 HQ Kingswood
