Results 1 to 2 of 2
Thread: Fuel pump fuse continues to blow.. VP
    Apr 2007
    Default Fuel pump fuse continues to blow.. VP
    heyas, i have a VP Exec 1992 V6. the fuel pump fuse keeps on blowing, just all of a sudden, this morning it was fine, after work i went through about 5 fuses. i have tried moving wiring around trying to see if there is a short but cant pin point it. the car is on gas, so when the fuel pump fuse blows it cuts out the gas as well.
    i also put a new fuse in, disconnected to fuel pump at the tank, run the car on gas, it runs for about 5 secs then pops the fuse, keeps running for another 5 secs and then just stops and wont start again. i guess the problem is with the gas. it had a 15A fuse in it, i tried a 20A (i know i should not do that) but still popped the 20A
    any suggestions?
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    I would jack the rear end up and secure it, then go to the back of the fuel tank where the pump is located and then you will see the wireing connector plug, unplug it, check the contacts, have a look in the immediate area for anything weird like exposed wires shorting.
  1. Need Help VT fuel pump fuse keeps blowing???
    By dieselmc in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-02-2011, 09:33 PM
  2. fuel pump fuse
    By vrss304 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-01-2009, 10:16 AM
  3. Replies: 20
    Last Post: 01-03-2007, 07:48 PM
  4. fuel pump fuse keeps blowing
    By stmcomms in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-11-2006, 11:54 AM
  5. vn running without fuel pump fuse
    By boothead in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-10-2006, 04:46 AM
