Results 1 to 6 of 6
Thread: Boiling Point
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Question Boiling Point
    Say, I've had overheating issues in the past, but I've solved most of them. Thanks to a VS V8 thick core radiator and a thermo fan override switch, I can fairly consistently keep my temperature under control by watching an aftermarket temperature gauge.
    Here's a question though - we know water in a pressurised cooling system will boil at around 130 degrees plus, right?
    That's all well and good to know, but we don't ever want to venture near that point in an ideal world. I run my after market gauge, and my standard dash gauge at the same time. The dash gauge is wired up just after the thermostat, getting the hottest point in the cooling system like the factory sensor.
    So, when my dash gauge is within farting distance of the redline, my aftermarket sensor is reading a happy 120 degrees. Something I try to avoid.
    Is it safe to say that 120 degrees and beyond is potential head gasket territory, or has 110 been a known failing point?
    I'm just curious if anyone here has some experience or knowledge in safe short-term cast iron V6 operating temperatures, because I tend to turn my thermo fans on at 100 degrees - and I'm wondering if this is an over-reaction?
    Could I be safely letting this temperature ride to 110-115 without being too concerned?
    Obviously cooler is better, and keeping it below 100 can't hurt anyone - but curiousity still gets the better of me
    </ramble>
    The 1972 HQ Kingswood
    VP exe
    Sep 2007
    well mate unless you have a modded cam or FI, it shouldnt really be an issue.
    the fan cuts in when it gets too hot.
    so far to ward off peak hour summer traffic over heats I have done the following-
    new water pump
    good coolant to spec
    new radiator
    power flush
    new coolant temp sensor
    new radiator hoses
    new water pump hose
    car actual;y driving quite cool now, i just did 1400km in her interstate and she didnt miss a beat, driven to work in the summer and yes the worst thing for overheating is sitting at the lights on hot tar in very slow traffic.
    they dont like it...come to think of it,, either do I,,too damm hot
    ill just add that i didnt do that stuff all at once but in repairs over about 6 months
    Gone Fishing...
    VP Executive R-spec
    Jan 2005
    Morton but why does it get so hot ? My V6 use to barely get warm, you must have blocked water passages or something. The coolant retard map retards the timing at 110c and beyond so that must be the happy time limit. 120c is costing you 3 degrees advance just on the coolant map alone
    Morton's Avatar
    May 2006
    Quote Originally Posted by Just_a_stocker View Post
    new water pump
    new radiator
    power flush
    new radiator hoses
    new water pump hose
    car actua;;y rin quite cool now, i just did 1400km in her interstate and she didnt miss a beat, driven to work in the summer and yes the worst thing for overheating is sitting at the lights on hot tar in very slow traffic.
    haha, yeah, it's only sitting in or crawing through heavy Brisbane traffic on a hot day that makes her overheat. It's only natural for a car to get hot, my only catch is the fan has never automatically kicked in at high temp, which is why I installed the override.
    Sep 07: new water pump
    Feb 08: good coolant to spec
    Feb 08: new radiator
    Feb 08: power flush
    Sep 07: new coolant temp sensor
    Feb 07: new radiator hoses
    Feb 07: new water pump hose
    New thermostat too, which basically crosses off all of those causes And my cooling system doesn't lose a drop between half-yearly flushes. Mystery, hey?
    Quote Originally Posted by greenfoam View Post
    Yeah i know, I'm fairly certain I have blocked water galleries somewhere, but the thermo fan can drag temperatures back to 90 degrees within a couple of minutes, so I don't stress. My only concern is that one day the fan's going to burn out and I'll have to shut her down on the side of the road.
    For now, during daily driving, she sits around 90 degrees. 95 if I have the front grille on. It's AMAZING how much temperature difference is made by taking those chunky plastic grilles off the VP
    VP exe
    Sep 2007
    guess you could always get a good battery. twin Ford fan and get it to cut in early...isnt there some kind of adjustable thing for that???
    Gone Fishing...
    savage1987's Avatar
    savage1987 is offline fail champion
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    yeah I'd imagine you can set up a similar setup to the common 5L mod .. twin AU thermos and a separate temp sender to run them at preset temps.
    Just a guess though, not sure of the work involved at all.
    Sam
    WTB: mulberry VN interior parts
  1. VH Battery overheating (boiling!)
    By bajab in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 11-04-2009, 10:41 AM
  2. New Speed Cameras - Point To Point
    By jaskel in forum The Pub
    Last Post: 16-10-2008, 08:58 AM
  3. VT Cambering? 4 point and 2 point
    By raZel in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-04-2007, 08:55 PM
  4. boiling over again :( vn
    By cliff_canon in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-07-2005, 09:53 PM
  5. Boiling Coolant
    By Bob129 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-02-2005, 08:48 PM
