Results 1 to 7 of 7
Thread: Knocking from front suspension
    VN Executive
    Apr 2007
    Wellington, New Zealand
    Default Knocking from front suspension
    when i turn into a hard right hand turn i get this single clunk noise coming from what sounds like the front drivers side strut.
    on the passengers front strut i have taken a picture of what could be the problem.
    pics suck because i couldnt find the camera so i used my phone.
    could this be the cause of the noise and if so what part do i replace it with.
    '97 VS Commodore + '98 E36
    Apr 2005
    have you checked the link pin bushes aswell??
    its a small pin that runs alongside of the strut onto a stabiliser bar and has 4 bushes?
    easiest way to inspect is to turn your wheel full lock to one side
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Looks like the bush in the control arm that the radius rod connects to has really had it. I would replace it urgently.
    MY RIDE
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    yes that bush has see better days .......replace as accentstencil had said...URGENTLY!!
    like it aint gonna come undon (cross fingers loll) but it will be unsafe under the ideal conditions
    VN Executive
    Apr 2007
    righto will get on to that this weekend.
    anyone know where i can get a replacement? repco?
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    Depends on your preference....probably gmh would be the best for a rubber type that is in your car now or you could go to a nolathane one as a upgrade although it would be more expensive.You can pull the old one out and the new one in (if you are using rubber)with a bit of threaded rod and a couple of nuts and washers and a piece of pipe and even leave the control arm in the car.
    I am surprised you didnt feel or hear and notice something happening a lot sooner given the wear on it
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
    VN Executive
    Apr 2007
    i think the knock is due to me driving over a road being sealed and a torrent of stones hitting the underside of my car, thus lodging a large amount of stones between the bottom of the spring and the plate underneath the spring.
    i had a look around the spring and sure enough there was a heap of stones and tar crammed in around the bottom of it.
  1. front suspension
    By impulsesv6 in forum General Discussion
    Last Post: 23-12-2007, 04:09 PM
  2. VZ SV6 knocking suspension noise
    By twb1979 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 14-12-2007, 12:23 PM
  3. Front knocking ....
    By Vc_Sleeper in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 07-02-2007, 06:57 AM
  4. Front suspension
    By full_noise in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 16-01-2007, 10:09 PM
  5. VZ Front Suspension
    By MySV6 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 27-06-2005, 04:19 PM
