Results 1 to 16 of 16
Thread: Quick question on vp s2 v6
    Vp s2 v6
    Apr 2008
    Default Quick question on vp s2 v6
    Hi guys,
    just a quick one my misses has a vp berlina s2 v6 and it has a bit of a miss or surge between 1,000 and 1,200 rpm the car runs fantastics when its cold but once its warm it runs like it has a cam in it the revs fluctuate. It is a pain in the ass when slowing down because the jerks around but if you just feather the accelerator a little it goes away i have tried tuning it i have checked coil packs tps switches, o2 sensors, map sensors air flow, everything really even went to a mate who has tek2 for it and the computer cant pick it up as any fault im lost has this happened to anyone?
    Vp s2 v6
    Apr 2008
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    My old VN v6 has the same issue mate, I never did get it fixed in the end. I liked to call it surging or hunting. It sounds kool lol. Give it a few hours mate, let the forum people wake up and have a read.
    Vp s2 v6
    Apr 2008
    thanks man its like a surge its only when its warm though as its my misses car she is freaking out a bit.
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    Quote Originally Posted by mprziv View Post
    It never ever got bad enough to stall on me, just sounded cool, haha, so many times I got asked if it was a 8, those people obviously didnt know what an 8 sounds like lol.
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    I can think of a reason that MAY be causing it, sticky lifters. I ts always good to run a oil flush additive to your oil just before you change your oil, this will free up all the old gunky oil, it actually cleans as Ive done it in my car and now the rockers are spotless. Only costs like $12 a bottle from a autoshop.
    Vp s2 v6
    Apr 2008
    same here its never stalled i just want to fix it though gotta keep the misses happy you know otherwise i miss out on loving lol
    Vp s2 v6
    Apr 2008
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    Quote Originally Posted by Mack View Post
    Did you see this one?
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Could be a fuel pump issue. Sometimes in their old age they get cranky when hot.
    Or something sticky. Sticky valve, lifter, spring... try Mack's advice of throwing some cleaner in there and flushing her out.
    How often is the car serviced? Do you have a list of items that have been replaced in the last two years, to help narrow it down?
    If you could go into a bit more detail on the problem, circumstances, sounds, amount of throttle, what gear you're in, at what speeds, etc that would be good Also where on the gauge "warm" is
    The 1972 HQ Kingswood
    Steery's Avatar
    Steery is offline AA 554 G
    94 VR SS M5
    Feb 2008
    Adelaide, near Cross Road Maccas.
    mine does the same thing, but it does it all the time.
    has stalled a few times in reverse with full lock on, but thats it.
    getting the valves, lifters checked and fixed if necessary. also changing the plugs.
    hopefully this fixes it.
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    Could be a faulty coil, bad lead... the list is long with such a general problem. Could be fuel, spark or engine related.
    Start replacing bits
    aZk.
    Morton's Avatar
    May 2006
    Quote Originally Posted by Steery View Post
    They all do that
    VN Calais SV89
    Mar 2008
    Grafton
    Had the same problems with mine 2day ended up resetting the computer while waiting i took out my throttle body cleaned the iac and throttle butterfly sorounds used a bottle of carby cleaner put it all back together and thought she was sweet but got into town 20klms away and started hunting again :{ , i head'd down to repco and grabbed another tps unit got home and installed and went and grabbed the kids and dun some shoppen and All sweet problem solved. Mind you the tps seemed to be working but when the motor was at operational temps it started playing up bouncen from 800-1300rpm.
  15. #15
    vr statesman 5.0 + vs exec s2 auto
    Mar 2006
    central coast, nsw
    I have had the same surging problem in my vp for the last 2 years,only when motor is at operating temp. fine when engine cold, was worse when using standard memcal BAMO265 . Have tried lots of standard vn-vp memcals, engine runs better since using sv3800 chip and premium 95 fuel. at the moment am using a Greenfoam economy type chip, so far pretty good. If your car has 2.5" exhaust and CAI, hi flow filter maybe the low backpressure leans the fuel mixture when throttle backed off. I have also replaced the coolant temp sensor and the IAC motor on T/B, MAP sensor in the last year but these didnt stop surging. And my car has new spark plugs + leads, have tried other ECU and coil packs,DFI module, so the surging must be a common problem with vn-vp v6 with zorst + breathing mods ,thats my 2 cents worth.
  16. #16
    Mar 2006
    central coast, nsw
    Default question on vp s2 v6
    almost forgot, last year i put a new TPSsensor on T/B , and new T/B gaskets plus engine has bellmouth removed. removal of bellmouth made no real difference good or bad , to surging. have also tried 4 or 5 different 02 sensors. do other vn - vp owners of stock untouched motors have these surging, hunting issues?
  1. quick question
    By adam69 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-09-2007, 10:04 PM
  2. Quick Question
    By wes_v8 in forum Site Feedback / Site Problems
    Last Post: 26-11-2006, 02:40 PM
  3. Quick Question
    By Calais3800 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-09-2006, 09:40 PM
  4. Quick Question...
    By VR_Project in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-07-2006, 04:34 AM
  5. Quick Question: VT SS RIMS = Quick Answer please
    By Henerz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-03-2006, 06:33 PM
