Results 1 to 11 of 11
Thread: Melted Fuse
    Dezza's Avatar
    Dezza is offline your local HSV dealer
    Cammed up Vy Clubby
    Feb 2004
    Thumbs down Melted Fuse
    Ok i just got this 91 vn and my aircon would come on and then stop then come on etc, so i thought must be outta gas.
    Well i was installing a stereo and under the dash i has a fuse melted to the board i had to use a bit of force to get it out and it has mangled the slot it came out of its all melted but the fuse is for the aircon, so i thought i would just leave it out as its comming inot cooler weather i wont be using aircon anyway.
    Well now the vn has started to overheat when its sitting in traffic or at lights but it cools down when i start to move again. Is the fuse that was melted for the aircon connected to the thermos as this is the only thing i can think of that has change to make the thermos not work and i cant hear them kick in when the temp gets to half way, also if i just throw another fuse in there could i cause more problems as something has really fkd that fuse and melted that slot or will it just blow again and ill have to work out a bypass ( any tech for bypassing for a switch to thermos).
    Sorry for the novel just trying to give as much info as possible
    vn calais, vs clubsport #137
    Jun 2005
    rule no1: dissconect battery when stuffing around with electrics.
    you may need to get a new fuse pannel mate.
    Dezza's Avatar
    Cammed up Vy Clubby
    Feb 2004
    Im pretty sure the fuse was blown when i got the car only had it a month and the battery was disconnected cause i was putting in the stereo when i found the fuse melted
    FXST01's Avatar
    FXST01 is offline The Grey Man
    VP V6 Auto Sedan
    Jun 2005
    El-Arish-Shamal-Sina-Egypt
    What colour was the fuse that came out of the holder?
    Have you checked Fuse 23 in the engine bay, that runs the engine fan (should be 30 Amp)?
    There are also two relays in the same area of the engine bay, 1 for aircon and 1 for engine fan. Might try swapping these about with the maybe horn and hi beam.
    Illegitimi Non Carborundum
    Dezza's Avatar
    Cammed up Vy Clubby
    Feb 2004
    Hey ive checked fuses and changes relays and i waited for the temp to get over half and the thermos didnt come on i uncliped the thermofan and hooked it up directly to the battery with two pieces of wire and they do work? i am stumped as to why they will not work when the engine gets hot
    Dezza's Avatar
    Cammed up Vy Clubby
    Feb 2004
    ok got all new fuses today and replaced them all fixed up the melted gap and got the aircon fuse in, thermo fan doesnt work still and aircon doesnt work at all. Any ideas???? is there a way i can bypass something to make the thermo fan come on?
    FXST01's Avatar
    VP V6 Auto Sedan
    Jun 2005
    Do you have a test light or multi meter?
    Is there power at fuse 23? Cooling Fan?
    Is there power at fuse 9? air con computer?
    Is there power at fuse 17? air con?
    In the diagnosis connector (passenger side footwell) connect terminal A & B. In a perfect world the fan will run.
    If all this doesn't work, i'll scan the page from the manual dealing with testing the cooling fan circuit.
    Dezza's Avatar
    Cammed up Vy Clubby
    Feb 2004
    cheers ill give this a go first thing in the morning and let you know if the fan comes on
    VXII Exec
    Jan 2006
    NTH Suburbs Melbourne
    Ok there's something wrong if your melting fuses. Fuses are there to protect the cable.
    For the A/C I'd be checking you didn't do damage to the wiring.
    As for the overheating, no idea.
    crazywog's Avatar
    crazywog is offline VS V6 ECOTEC KING
    my fully shick holden bro
    Oct 2006
    In my fully shik holden bro
    take it to ur mechanic to have a look see wat the problem is and see if he can diagnose it with there special computer if he finds the problem then u can go ahead and fix it thats my 2 cents worth mate.
    RAJAB RACING
    FullBOOST
    PRESTON AUTOMATICS & DIFFERENTIALS
    etstreet.com
    Dezza's Avatar
    Cammed up Vy Clubby
    Feb 2004
    yeah dont really want to take it to a mechanic dont really want to spend money on it as its just a run around hasnt overheated for a few days but i can smell coolant when i drive in the cabin but cant see any comming from anwhere. the fuses are all back but the aircon no longer works and the thermos still dont work. Just want to sell it now
  1. VK Fuse box melted
    By vknut in forum Electrical Wiring / Questions
    Last Post: 10-11-2007, 03:13 PM
  2. VL Melted fuse rail
    By manualwagon in forum VL Holden Commodore (1986 - 1988)
    Last Post: 05-11-2007, 05:17 PM
  3. melted fuse box
    By VKnVLCalais in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 26-11-2005, 12:16 AM
  4. melted fuse
    By VNCommo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-06-2005, 08:22 PM
  5. Melted Fuse
    By midnight.outlaw in forum Electrical Wiring / Questions
    Last Post: 31-03-2004, 05:12 AM
