Results 1 to 20 of 20
Thread: seat winding itself back! Can I tighten?
    Apr 2005
    Default seat winding itself back! Can I tighten?
    Hey all. The drivers seat is winding itself back into Muzzah position whenever I get in to drive her and seing as I like to see out the front windscreen, I need to know if I can tighten the winder or does it have to go to the trimmers? If thats the case, I don't want to put the (VP)SS seats in if I don't have to...
    VP Exec
    Jun 2005
    I really should do a "How To" on this as it's a common problem:
    There is no need to remove the seat covers so no, a trimmer isn't necessary.
    The seat creeps back because the the little piece of foam rubber that acts as a brake has deteriorated. The foam can (or not, if it has disintegrated) be found behind the seat recliner knob.
    The fix will cost you nothing and takes about 5 mins..
    You need a gasket scraper (or perhaps a wood chisel), a pair of outside circlip pliers, a blade or knife and an old VN-VS live axle anti-roll bar link rubber. You could get creative with something other than the link rubber; something like a piece of an old computer mouse mat would do.
    Use the gasket scraper to lever out the centre cover from the recliner knob (if you are careful you won't mark the cover or knob) then push the circlip pliers into the split in the recliner knob to spread it, allowing you to pull the recliner knob off the seat. Again use the circlip pliers to remove the circlip holding the recliner knob "brake" and retaining washer (easy to see what I mean when you do it) and remove any remnants of the foam still left.
    The "brake" can then be replaced with a slice of the link rubber (or mouse mat foam) as thick as you can use while still being able to push the washer on and get the circlip back into the groove - about 5mm give or take. Thicker will make the seat harder to adjust, too thin won't work.
    Then put everything back together. Easy.
    Apr 2005
    VN Wagon
    Feb 2005
    Doctor Bob's Avatar
    Doctor Bob is offline Grandpa
    VT V6 Exec & VN V6 Exec
    May 2004
    Mornington Peninsula
    there used to be a repair kit but its NLA from Holden, it had a different washer setup.
    basically as has been said you need to put more preload on the mechanism
    savage1987's Avatar
    savage1987 is offline fail champion
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    OMG you are a legend Cheap6, both my cars do this, on both front seats, and it drives me insane!!! Also not a bad idea to tighten any allen bolts you can find if you do ever have the seats out as they develop that annoying wobble (whole back of the seat can be shaken by the headrest)
    Sam
    WTB: mulberry VN interior parts
    m3taL's Avatar
    m3taL is offline For what its worth.....
    88` S1 VN, 5spd & 94' VR Wagon
    Aug 2006
    Bendigo, Vic
    well i know what im doing tomorrow night!!!
    My missus come with me in my car the other day and she was paying out on my fully sick "Muzzah" seating arrangement.. im so over lifting it back up!
    Cheers "Clix some scales"
    m3taL... for what its worth...
    http://s92.photobucket.com/albums/l9...rrent=vn-3.jpg
    My Ride
    88' VN 3.8 5spd, Custom CAi, 2.5 High-flow zaust && Foaming Tune!!!
    Turbo Manifolds and Plumbing Near completion!
    Family Ride:
    2007 Kia Grand Carnival Lux Model
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Mmm yes cheap6 you have a reputation present from me too!
    Maybe I'll use loctite on those frame hex bolts this time too... I already tightened them up once before in the VN.
    Sam
    Tom_1569's Avatar
    Tom_1569 is offline Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    Legend, but now i have a job to do lol. Since alot of people are oviously going to be doing this, why dont we all take photos of the process, put them all up and make the best detailed work guide we can, since everyone will have experience at doing it, im sure we can make a very comprehensive workguide.
    Quote Originally Posted by alien View Post
    I have been hit by oil badly once while in Army uniform on a massive roundabout that doesn't exist anymore. Spun 180 degrees to face oncoming traffic.
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Not a bad idea, although with my 2 cars in almost constant use I don't know when I'll have a chance!!
    02' VX Berlina 5.7L
    Feb 2005
    S.E Melb
    Quote Originally Posted by Cheap6 View Post
    Really helpful info. Yes, a How To thread would be a very good idea.
    I will have a go at doing mine soon, when i get some circlip pliers. Is there anything else I could use instead of circlip pliers?
    VP Exec
    Jun 2005
    Quote Originally Posted by SAMO-87 View Post
    I've had photos ready for a How To since I did my seat a few months ago but haven't yet made time to put them up. It wouldn't be much different to what's already here except for the images anyway. I'll get to it eventually .
    You could get the knob off the seat with two flat blade screwdrivers in the slots. I found the pliers easier. I'm not sure how you would get the circlip off. You could improvise something but probably easier just to wait and buy a cheap Chinese made set of the pliers. Some of the "Dollar Discount" shops (those places that sell kitsch crap) sell tools and I've seen them at the markets too. For a one off job it won't matter if they're rubbish but not if you want to use them again for other jobs.
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Goes out to shed now to try this.
    and 3 Dangerous non ABS VN's
    88GreenVN's Avatar
    Jun 2006
    Some photos of the quick job before work today. Now after completing this easy easy fix I shook the seat and it did not move 1 bit.
    And &%#@*!??%* for not finding this some time ago. Now my mouse pad was killed in the process of this job and is 25mm shorter
    The search button is NOT my freind now.
  15. #15
    Jun 2005
    so the whole thing has 2 circlips on it?
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
  16. #16
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by stocky View Post
    No just 1 circlip and 1 metal washer plate and then the mouse pad rubber washer. Soooo easy to fix - My mouse pad ain't too happy And the circlip suffered abit - buchered is a good word. In a rush to get it done before work today
  17. #17
    VP Exec
    Jun 2005
    Quote Originally Posted by 88GreenVN View Post
    See how you go with just one thickness of the mouse mat. You may need another one to stop the seat slowly creeping back. It depends on what is in the map pocket on the back of the seat .
    To cut the centre hole neatly out of whatever material anyone decides to use, a short length of suitable diameter pipe can be sharpened on one end using a a grinder (or I guess with a file if you like hard work) to make a punch.
    88GreenVN since I haven't stumped up the photos and you have, feel free to post it in the 'How To' section with whatever text you think is appropriate. I can put my photos later if it will add anything.
  18. #18
    88GreenVN's Avatar
    Jun 2006
    I thing it was funny hacking up the mouse mat with out a coffee. - But I had the seat all ready to toss out and thought I could fix this - WOW. and it worked a treat.
    Dont know how to do a "How to" and a round hole would be better. Just had to have a go at it right there and then.
  19. #19
    DannyboyDS is offline Just hand me the pliers.
    VS Berlina
    Feb 2007
  20. #20
    88GreenVN's Avatar
    Jun 2006
    I should read the Vn VP section more often.
    Gentlemen, I bow to you.
    Some good stuff - Thanks to Stocky for saying this thread was around and to Savage1987 for tracking it down and Cheap6 for the write up.
    Auto recline seats were a real pain and such an easy fix. Soooooo much easier than swapping the cloth and foams over
  1. Back Seat
    By s_pack in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 10-10-2007, 05:04 PM
  2. Back Seat?
    By HoZy in forum The Pub
    Last Post: 06-04-2007, 11:31 AM
  3. winding back the counter
    By tigga17 in forum General
    Last Post: 23-07-2006, 07:11 PM
  4. Winding odometer back
    By chopsy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-07-2006, 11:14 AM
  5. Back Seat
    By wooly72 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-12-2005, 07:47 PM
