Results 1 to 9 of 9
Thread: Fuel Tank
    bboystyles's Avatar
    bboystyles is offline chicks dig guys wit utes
    VP ute
    Sep 2007
    Perth, WA
    Default Fuel Tank
    hi all
    just wondering. how bigger job is it to replace a fuel tank and all the pipes nd lines? also how much wuld i be lookin at for the tank nd lines its self. i have a VP ute, can i only put VP fuel tanks in or do newer ones fit? and lastly can any mechnic like Automasters do the job? can anybody shed sum light on this
    cheers
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    It is not a hard job to remove the fuel tank providing you empty it first. Just disconnect all the hoses and electrical connector and then undo the straps that hold the tank up. I can't help with the other questions.
    MY RIDE
    calaiscruzer's Avatar
    calaiscruzer is offline I drink beer, and I vote!
    Atlas Grey VN SS
    Sep 2007
    VIC
    I got a second hand tank put in last year, cost $40 from wreckers, $30 for them 2put it in and replace all fuel lines. I got them to replace all fuel lines and flush the 'new' tank also. Spent like $20 on fuel lines. Mind you, these wreckers were real good guys, did did things pretty cheap 4me. Normally it would take around 1/2 hour 2replace tank, most mechanics charge $30-$50 per hour, so not much.
    Black VN MANUAL
    Feb 2007
    Top of Vic
    Its easy undoing the lines and dropping thr tank, but getting another 1 back up is abit tricky if you havnt done it before, only because of the breathers and that ontop of the tank, they are tricky and you dont want to do the tank up and block of the lines.
    ~ VN POWER ~ Click the scales
    Jul 2005
    just put a drop tank in my car, in half a day not knowing what i was doing. If your gonna do it make sure u put in atleast 20 letres if fuel or the pump wont prime or it will but will die on you like what happened to me tonight, got stuck in the middle of an intersection .
    Black VN MANUAL
    Feb 2007
    Top of Vic
    VP exe
    Sep 2007
    yes it is kind of easy
    but would be a lot easier with a mate to help you.
    the tanks only held by a few straps and bolts , then it lowers down and you disconnet the lines and the fuel input thing ( where you put the petrol bowser in).
    the you do all the breathers while its out and slap it back it.
    easy but a bit awkward, but you will not have any probs
    the lines are just rubber hose about 5$ a meter
    Gone Fishing...
    bboystyles's Avatar
    VP ute
    Sep 2007
    Perth, WA
    yer i want it done professionally, nd like everything replaced. coz its **** atm. wuld like a 1999 VS tank be the same as my VP one? coz i want like as new as possible
    bboystyles's Avatar
    VP ute
    Sep 2007
    Perth, WA
    u no the breather jus under the bowser, is there supposed to be a hose going from there to sumwhere else?
  1. Fuel Economy Per Tank Of Fuel
    By HoZy in forum VE Holden Commodore (2006 - ?)
    Last Post: 03-09-2010, 12:30 PM
  2. Fuel Economy Per Tank Of Fuel
    By HoZy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-04-2009, 10:24 PM
  3. Fuel economy per tank of fuel
    By HoZy in forum VL Holden Commodore (1986 - 1988)
    Last Post: 05-05-2007, 06:58 PM
  4. Fuel Economy Per Tank Of Fuel
    By HoZy in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 05-05-2007, 09:39 AM
  5. Fuel Economy Per Tank Of Fuel
    By HoZy in forum VY Holden Commodore (2002 - 2004)
    Last Post: 04-05-2007, 09:01 AM
