Results 1 to 5 of 5
Thread: dash brake light
    VP Calais series 2
    Jan 2008
    Default dash brake light
    I am getting a vp calais ready for rego and when you apply the brake the brake symbol lights up on the dash, the car has been off the road for a year, i have checked all fluids, the brakes dont feel spongy i think it could be the brake switch, any thoughts? Also i have noticed the engine light comes on very occasional on the dash as well.
    PRH
    PRH is offline
    vp s utility,and a KENWORTH
    Apr 2007
    Mildura Victoria
    Have you done any work on the brakes at all,not really sure but on the earlier cars once the master cylinder brake fail switch has operated it needs to be replaced,try unhooking it and see what happens
    Phillip
    m3taL's Avatar
    m3taL is offline For what its worth.....
    88` S1 VN, 5spd & 94' VR Wagon
    Aug 2006
    Bendigo, Vic
    Check the VAC Hose into the break booster, had to replace mine when i got my car that had been off the rd... just a thought...
    also have you checked ecu codes cos engine lighht comes on for a reason ususaly... or maybe it could be a fault in your dash Grounding which is making the lights come on due to feedback to find a ground... if the light is ligting up "Dim" this could be the issue.
    also could be a leaky master cylinder
    jamo
    m3taL... for what its worth...
    http://s92.photobucket.com/albums/l9...rrent=vn-3.jpg
    My Ride
    88' VN 3.8 5spd, Custom CAi, 2.5 High-flow zaust && Foaming Tune!!!
    Turbo Manifolds and Plumbing Near completion!
    Family Ride:
    2007 Kia Grand Carnival Lux Model
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    I'm not familiar with the VP warning lights but if the symbol you are talking about is a light globe symbol then that means a brake light globe has blown.
    MY RIDE
    Ado's Avatar
    Ado
    Ado is offline Are we there yet?
    vsII statesman L67
    Apr 2008
    Mr bean disconnect ur battery for 30 seconds and reconnect problem fixed.
  1. Lvl 3 Dash Conversion Problem: H/Brake Light comes on while driving.
    By nugatory in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-10-2007, 07:26 PM
  2. brake light and dash lights fault
    By flawless in forum Electrical Wiring / Questions
    Last Post: 30-08-2006, 10:57 PM
  3. Replacing dash light AND radio light
    By CLE in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-05-2006, 05:39 PM
  4. Dash Light Warning Light
    By Bongo in forum Electrical Wiring / Questions
    Last Post: 07-10-2005, 08:17 PM
  5. VZ dash fog light warning light
    By Torquative in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 14-08-2005, 07:13 PM
