How do i adjust the timing on my vp auto it is running to fast and when I take my foot of the break at the lights of in traffic it takes of like a bat out of hell what do i need to do???
by timing do you mean the idle speed? my guess would be throttle somehow stuck open a bit or not closing completly maybe?
The Daily VN T5V6
355 VN GRP A REP
Or the Idle control valve has some carbon built up in it and is sticking open...
Try a ECU Reset via Disconnecting the battery for 5 mins then reconnecting it and Starting the car and holding the revs at 3000rpm for 30 sec.
Also as Mischa Said could be the TB Butterfly held open do a Visual inspection see if its stuck or not...
Also with the visual check the Throt Cable isnt cought up or the nuts havnt come loose or somthing like that.
m3taL... for what its worth...
http://s92.photobucket.com/albums/l9...rrent=vn-3.jpg
My Ride
88' VN 3.8 5spd, Custom CAi, 2.5 High-flow zaust && Foaming Tune!!!
Turbo Manifolds and Plumbing Near completion!
Family Ride:
2007 Kia Grand Carnival Lux Model
