Results 1 to 4 of 4
Thread: V8 to V6 conversion
    vr BT1
    Oct 2007
    Default V8 to V6 conversion
    Gday, will the V8 auto transmission in a vn bolt straight up to a buick v6, and if not what is needed as i have two complete cars and other needs for the 5lt
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    Auto or manual?
    Im not 100% sure on auto, i think it will with the correct bellhousing but dont quote me on that.
    Manual is a bit different, now i forget which way it goes but they have different input shaft lengths.
    Pretty sure its V6 is shorter so a V8 can be machined to fit a V6 but not the other way around. That makes sence as the V8 motor is essentially longer to accomadate the 2 pistons.
    So a V8 box could be machined to fix a V6 and if i have ti the wrong way around, a new input shaft could be installed.
    The ratios in the box are different, V8 1st is alot shorter.
    Sorry, that post was a bit vague.
    aZk.
    vr BT1
    Oct 2007
    Yeah sorry is an auto, thanks for the reply, any more suggestions welcome
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    no.
    diffrent bolt pattern, v8 has a point at the top, v6 is flat.. also the input shaft for the manuals is diffrent.. short answer tho no it wont.. thats why the v8 transmissions go for heaps more on ebay
    why would you want a v8 trans for a v6 anyway? only diffrences are a few valves, making the v8 box slightly stronger
    you can pick up a v6 box for $100 easily!
    and by the way azk, the box's arnt longer, the tail shafts are just diffrent lengths
  1. conversion people conversion
    By flynn84 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-09-2007, 01:25 PM
  2. VN conversion to LSD
    By savage1987 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-09-2006, 02:03 PM
  3. Vt gas conversion
    By satos in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-07-2006, 08:16 PM
  4. V6 VT conversion
    By sharpy_2020 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 31-07-2005, 05:43 PM
  5. Vp manual conversion and vn auto conversion
    By gumbs in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-06-2005, 11:08 PM
