Page 1 of 2 12 LastLast
Results 1 to 25 of 29
Thread: coolant leaking timing cover temporary fix???
    Apr 2005
    Default coolant leaking timing cover temporary fix???
    Is there anthing I can use to gack up the cooling system temporariliy to stop a leaking t/c on a s1 VN 3.8? She's peeing out from behind the engine end of the bottom hose and I need the car to drive 2094k's(Adelaide to Sydney(ish) round trip-return with a light trailer load(I know-BAD TIMING!). How goods Bars Stop Leak???
    If I could fix it straight away, I would, but I can't 4 a couple of days...
    vp exec
    Dec 2006
    vaucluse, sydney
    i have used chem-e-weld in the past and it has worked ok... makes the gaskets swell up and close up small leaks.... the process to do it is a bit painful (read the bottle) but it works ok... i also had to remove/clean threads/tighten all of the inlet manifold bolts to stop various minor leaks. cheers pete
    KRUPTD is offline VN BT1 5L
    VN BT1 5L,5spd,LSD
    May 2007
    Griffith, N.S.W
    Clean up where the leak is and surrounding area with wax and grease remover or brake clean.go buy some arildite (i hope thats how you spell it).Mix some of this up and use a scraper or a paddle pop stick and gentle fold it into the leaking area and surrounding area too,make sure you do this when the engine is cool and let it set at least 12 to 24 hours before starting the engine.This should hold,but for how long???no one knows.
    (KRUPTOR)VN BT1 5L TTB's,MANUAL,LSD
    UNKNOWN's Avatar
    UNKNOWN is offline DEFECTED
    95 VR SII BT1 5 Speed
    Jan 2008
    NW Adelaide
    It dosnt take long to change that gasket.
    Shut up when I'm talkin' to you, you hear me, answer me!
    VN Executive
    Apr 2007
    Wellington, New Zealand
    Apr 2005
    Quote Originally Posted by peter65 View Post
    Quote Originally Posted by KRUPTD View Post
    Cheers guys, thanx for you help, I used the chemiweld and the leaks gone, for now. I've got some stuff like liquid metal which needs to be kneaded together, it's a two part putty that, with a clean surface, seals up any leaks. When I get back home, I'll do the gasket and all the 'o' rings aswell....
    vn/vp Speedway Street Sedan
    Sep 2005
    I hope not but i have this horible feeling that halfway through your trip you are going to be on the side of the road with steam pouring out from under the bonnet.... there is nothing like fixing it right the first time...... but just think, the money you save now can go into that nice expensive complete engine rebuild after you have fried and warped everything!!!!!
    Good luck dude!
    Jun 2006
    make sure its not the small hose just above waterpump .
    My Car has been doing this for years but only a drop here or there, to stop this I use a product called Car Go , it comes in a clear bottle with white lid and when you look at it there are copper/silica powder at bottom of bottle that when you add heat and water goes to a solid state which is excellent for filling holes or cracks in gaskets or heads.
    flush your cooling system with the garden hose then fill back up and shake up bottle of cargo and add directly to radiator and go for a good drive ,leave this in for a few days of driving. then drain radiator then add coolant .
    If you cant afford to fix it properly then i would buy a few bottles of it for your trip and carry lots of water in bottles with ya.
    Car go is sold at super cheap auto , Kmart , repco ....
    yes there are other products but I have been using this stuff for like 10 years ...
    Also it wouldnt hurt to put in those coolant pellets they sell at holden to lubricate your waterpump and keep gaskets in better condition.
    Vn executive 1990 200,000kms as of 13/6/08 , oil changes every 5000kms since it rolled out the factory , strut brace for hard cornering, kn pod filter, Ngk iridiums sports exhaust..what else can I say I love my holden
    Apr 2005
    Yeah, cheers AGR, the Bars Stop Leak's got the black pellets and lubricant for the w/p brg aswell. The other 1/2 wants to go with us, which means the kids too, so I reckon it looks like the car'll be off the road for the day while I replace the gasket and the balancer seal, while I'm at it. If I was just going by myself, I'd just go, but with the family, don't want all of us to be hitching.
    I went to my old work and used their pressure tester and found it coming from the t/c- wish it was as simple as that hose, even tho' that one could do with replacing....
    I have a new thermo /hsg.(remember, it's a series 1.) and attempted to replace it, but it was an absolute bitch to move/dislodge from the plenum, so I left the old one on. Not looking forward to getting that off when it has to go...
    Anything else needed, other than t/c gasket and balancer seal??
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by NOGEN 3 View Post
    Possibly a puller for the harmonic balancer, if you don't have one already.
    MY RIDE
    Apr 2005
    FYI- the price on a new timing cover for a series1 VN is $700.00!
    To put this in context, I paid $1500 for the Berlina wagon, with all the Berlina goodies, plus 16" VR Clubsport copies.....
    That's OK, if the t/c is corroded, I'll just get an alloy welder to weld it and take it to a cylinder head machinist to dress up the gasket surface flat, just gotta find 1 round south side of the city.
    Hope to christ it's just an "O" ring ....
    Standard balancer puller? Guy reckons I'l need a special Holden V6 puller??
    Running outta time here- gotta go in 7 days....
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    what about wreckers? they should be alot less then 700...is teha genuine if so look around at other places
    VP exe
    Sep 2007
    is there some stop leak **** e you can buy from repco??,, might give you a bit of time..
    regards
    Gone Fishing...
    Apr 2005
    Quote Originally Posted by jas98 View Post
    That was a KC brand- the cheap 1! Genny's prob dearer from Motor Traders, yet always cheaper than from Holden ....
    Wreckers are scumbags and I'd rather spend more on someone more reputable...but not $700!
    Used the BarsLeaks. Worked 'till this afternoon- spewin'
    Got the kit- O rings, gaskets & t/c seal- Get going on it tomoz after picking the kids up from Vacation care...
  15. #15
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    ah ok
    yeh shouldnt be too hard...when i did mine it only took a few hours
    good luck and let us know how it goes
  16. #16
    Apr 2005
    I'l be doing it with no help and using the force(no workshop/service manual), so it should be interesting.....
  17. #17
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    wtf mate $700??? i could have that fixed for $10 and a hour later...
    its simple, remove thermo
    remove balancer, water pump
    undo all hoses
    undo all bolts on the housing
    unto the 3 bolts on the sump into the timing cover
    pull the cover off
    clean surface, seal with gasket goo and gasket, seal and bolt back up
    when i was playing with return lines for my turbo i tapped the timing cover seal and did a return line in there,,
    $700 my ass! :P its a 5 min job and you know it... 2000km ****ing coolant is a stupid idea btw, the seal is a $8 part even comes with a crank seal for the timing cover
  18. #18
    Apr 2005
    Quote Originally Posted by PaRaDoX616 View Post
    undo all hoses
    pull the cover off
    17-04-2008, 10:33 PM
    NOGEN 3
    Bite the reality sandwich
    Ride: N/A
    Trade Rating: (0)
    __________________
    Ashley
    BAN LOW PERFORMANCE DRIVERS, NOT HIGH PERFORMANCE CARS!(beware of imitators!)
    SO MANY ASSHOLES, SO FEW BULLETS!
    My Ride <http://forums.justcommodores.com.au/showthread.php?t=24142>
    Nuff said....
  19. #19
    Apr 2005
  20. #20
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
  21. #21
    Apr 2005
    so it was just the gaskets then?
    glad ya got it sorted
    Yeah m8, that's all it was, luckily. Looked like it had been dodgied with a 1/2 ton of silastic before. I reckon, given another week or so, the other side would have let go aswell...
    Had to ride 20 k's for another gasket(Mind you, I'm 38 and ony 1 gear on the deadly treadly, lol), as the first one slid and couldn't get the bolts either side of the oil pump in, then I had to pick the kids up(5k's by bike-Dropped the kids bikes off in the morning b4 starting on it). By the time I got back, the silicone had hardened(surprise, surprise) so I left it overnight. This morning, I did the ride, got the new gasket, recleaned/redid the t/c and turned it over a few times with immobiliser on, then fired it up without the radiator and fan in and the trans line looped. then refitted the cleaned up radiator(had dirty trans fluid mud clogging a good 1/4 of the rad- not that it affected the guage)
    She runs!, And no leaks!
    Took her to the shops to get some heat/pressure in the cooling system, pulled up in the driveway- no problems at all and whats more-NO LEAK!!
    (If I seem surprised, I am. Only because I had a genuine GTR torana that I stripped for a ground up, only to sell in pieces at a 10g loss(10 years ago-Let's not get into how much they're worth now- I'm still kicking myself.) and the VPSS 5 speed, sitting in the single car garage on standswith 1/2 an engine and no front end suspension...cars get started and don't get finished round here, but I'm about to change that with the SS...)
    Noticed I didn't have to take off the alternator/coil pack bracket, but cest la vie(that's who gives a ****, in French),
    NSW....Here we come!
  22. #22
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    haha awesome to here. always a good feeling when things turn out to plan
    at least its done and you don't have to worry about it anymore and can enjoy your trip.. have a safe trip
  23. #23
    Apr 2005
    So long as nothing else ****s itself- remember it's a 17 year old car... lol.
  24. #24
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
  25. #25
    Apr 2005
    She'll get me there- I treat her better than her last owner obviously, lol
LinkBacks (?)
  1. 24-04-2008, 07:53 PM
  1. leaking coolant
    By quiksilver1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-04-2008, 10:11 PM
  2. Timing cover
    By furion in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-11-2007, 03:54 PM
  3. timing cover
    By callum87 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-10-2006, 07:52 PM
  4. Coolant Leaking Help Vn
    By WeBsTeR in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-01-2006, 08:18 PM
  5. timing cover
    By dave671 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-06-2005, 11:09 PM
