Results 1 to 21 of 21
Thread: Just KILLED another L3 Dash
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Default Just KILLED another L3 Dash
    OK now I'm realy peeved. After converting the new green sedan to A L3 dash and got that all working (Brown wires moved to the wrong slot in Connector 1) I go to put the Wagon dash (used in the sedan while I got the sedan working) back in the wagon and TDE = 0 and no fuel gauge again.
    WHAT's the go here Why? I have not changed the wires in the wagon. Can the PCB just die like that? I've tried 3 trip computers in it with no change. Low fuel light comes on and fuel gauge does not move.
    AND if I put the dash back into the sedan it works.
    Put the dash from the sedan in the wagon and no workies either.
    Time for something to drink
    and 3 Dangerous non ABS VN's
    88GreenVN's Avatar
    Jun 2006
    Anyone help with the DTE = 0 bit.
    88GreenVN's Avatar
    Jun 2006
    Can this part be different between models?
    wrx884's Avatar
    wrx884 is offline WA's ASR Rep
    VT Commodore Exec/5L VP Calais
    Mar 2006
    Do u know if the VN clusters r the same as VP i got a couple clusters with me and i think 1 is from a VR so i got somthing that might help but not if the VNs dont have the PCB covering on the back of the clusters?
    Check out my ride in progress.... 98 VT V6, V8 Supercar kitted
    Daily toy.... 92 VP Calais 5L
    88GreenVN's Avatar
    Jun 2006
    L3 Clusters from VN VP VR VS all look the same. But VR/VS wont work in a VN.
    I'm trying to work out why I get DTE = 0 in 1 VN and 100km DTE in the other VN with the same cluster. The PCB looks the same and have the same numbers on them.
    It's got me buggered as to why it wont work. Cant find what is the difference between them.
    DanVN's Avatar
    DanVN is offline Cruizin' in style!
    01 WH Statesman International 5.7L
    Nov 2007
    Western Suburbs, Vic
    my moneys on a broken track or solder somewhere, thats what i put mine down too scrapped the cluster and bought a new one =)
    88GreenVN's Avatar
    Jun 2006
    Thats what I was thinking - I've killed it - but then it works in the other car. The wagon has a 89 Calais loom in it. The green sedan has the L3 wires grafted into it.
    I've missed something somewhere. Swapped the wrong bit or something. Done something stupid...
    wrx884's Avatar
    Mar 2006
    i thought they were the same across models and alot of ppl have said it 2 but wen u say they r the same numbers do u mean every single pin and writing r the same? i'll post up my connectors n tell me if urs reads the same
    wrx884's Avatar
    Mar 2006
    Edit: hmmm it didnt work wat i wanted 2 pm me ur email and i'll send it via email coz i got it there already
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by wrx884 View Post
    The PCB numbers are the same on both clusters & connectors
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    The wiring is differnt between the VN's and VP;s the cluster swap isnt as easy in the VP...
    Not that its fuel related though...
    Hard to diagnose without the car, have you changed fuel tank sizes?
    aZk.
    burnz's Avatar
    burnz is offline dah dut dut da dah
    2010 CRUZE Diesel
    Jun 2005
    springfield
    check the colour code's of the wireing plug maybe two are reversed, making the fuel gauge go in
    opposit direction
    Research has shown that men usually sleep on the right side of the bed.
    Even in our sleep we happen to be right.
    Powered By Garrett
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by azkwazere View Post
    aZk.
    Nope no fuel tank change. Just pulled the cluster out of the wagon to get the new green sedan going (when the brown wires were in the wrong spot). Got the sedan sorted out and whet to put the cluster back in the wagon and TDE = 0.
    I've looked at the C1 plug in the wagon and the brown wires are in the correct spot.
    I give up for now and will get a new cluster and see if that fixes it.
    ScoHar's Avatar
    ScoHar is offline Jizz in my pants
    02 VX Equipe V6
    Apr 2006
    CHCH, NZ
    Default Worth a look
    This may sound strange, but something worth having a look at, After i did my audio install my LVL 3 cluster was doing the same, fuel light on gauge out of wack and 700+ kms on my DTE, then next time starting it up went full gauge 0=DTE and fuel light on.
    I traced it to where I bolted my sub in the boot I had drilled through the wires. Not sure if you'd make a dumb mistake like I did but worth a look.
  15. #15
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    i have sum clusters lvl 3 in bits if u need any parts. that module u showed from behind the dials are different on v8's than to v6's different part codes
  16. #16
    Set of thongs
    Dec 2005
    Stonedville
  17. #17
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by hartsc View Post
    I didn't do any drilling.... But the chasis man took the tank out!!!
    Maybe he messed with the wires a bit. OR MELTED SOME
    That could be it!!
  18. #18
    88GreenVN's Avatar
    Jun 2006
    OK tested a L2 dash in the wagon and temp gauge works fine but no fuel signal. Took the trip computer out of the L3 cluster and just plugged that into C4 and it shows 610 DTE. So it must be the sender unit or the wire from the sender unit to the Dash. So tonight I'll run a test wire to the sender unit to see if I can get some life.
    Thinking here why dont I try the diagnostic mode in the L3. Hmmm should have done this first..... What a wally.
  19. #19
    88GreenVN's Avatar
    Jun 2006
    Car is now fixed with fuel gauge working and TDE not = 610.
    It was the wire between the sender unit and the back door. I ran a wire from the sender unit up through the bolt hole for the baby capsule mount and spliced it into the loom (tan wire)
    Looks like the wire was cut while the car was being repaired.
    Had I not played with the cluster in the first place........
  20. #20
    vp
    May 2008
    Default vp l3 dont know how to ask a question on this site
    Quote Originally Posted by 88GreenVN View Post
    I have l3 vp dash it the one with the digital read out at the bottom what do I have to do to get the digital part to work properly before I had the other dash all needle and I know that instead of the left blinker it flashes push remote but that should be easy to fix and I also have v8 l3 dash out of a vp I was toldplease answer my question if you can
  21. #21
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by novice vp View Post
    If the left flasher is going to the Press Remote - you have the wrong dash cluster for your car.
    To correct this you will need to find the left flasher wire in the (1 of 3 plugs behind the dash) and mate it to the cluster.
    You cant just swap the front cover over (lens) and hope it will work. On the PCB you will have the 4 connector pin outs number 1.2.3. and so on.
    You should have 1 below marked in BOLD.
    This is a list of Calais/Statesman/Caprice Cluster part numbers
    For VN, VP, VQ
    VN
    92033603, V6, P.O. UA6 EXPORT
    92038148, V6
    92035022, V8, EXC P.O. UA6, EXPORT
    92038149, V8, UA6, EXC EXPORT
    VP
    92038533, V6
    92038539, V8
    VQ
    92038148, V6, SER I
    92038533, V6, SER II
    92038149, V8, SER I
    92038539, V8, SER II
    92033606, V6, EXPORT
    92035024, V8, EXPORT
  1. Killed 3 Tie-rods!
    By Keesh in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-03-2007, 11:06 PM
  2. friends VR killed my VN LOL!
    By h0Ld3n`VN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-11-2006, 01:40 PM
  3. Killed V6
    By corsa2nv in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-03-2006, 11:24 AM
  4. i think i killed my cluster :(
    By PaRaDoX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-02-2006, 11:38 PM
  5. Hit and killed a pig.
    By Silver in forum Jokes/Humour
    Last Post: 01-08-2005, 09:42 AM
