Results 1 to 7 of 7
Thread: V6 oil pump help
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    Exclamation V6 oil pump help
    are there any differences between the s1 and s2 onwards buick oil pumps other then the stronger bypass spring on the s2 that increases max oil pressure from 50psi (s1) to 60psi (s2 onwards).
    i want to make sure i've got heaps of oil pressure before i subject it to a shot of nitrous. i'll be fitting a new timing chain most likely to ensure accurate cam timing and will obviously have the cover of so can do the oil pump at the same time if required
    cheers
    Body by Holden, Soul by Brock
    the Legend will live forever
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    Apr 2006
    Auckland NZ
    Quote Originally Posted by PaRaDoX616 View Post
    im not sure on this but why not fit a oil pressure gauge...????
    i have and it's as it should be (for a s1 engine) but i want more oil pressure as cheap insurance and my gregories says the s2 engines have more oil presure
    s1 max pressure 50psi
    minimum pressure 40psi @ 1850rpm (operating temp)
    pressure relief spring = 64.8mm
    s2 max pressure 60psi
    minimum pressure 55psi@ 1850rpm (operating temp)
    pressure releif spring = 66.3mm
    so the relief spring is definitly longer resulting in the increase in max pressure, however the s2 minimum pressure is 15psi more at the same RPM and that wouldn't be related to the presure relief spring. i'm guessing that there must be some sort of difference between the 2 pumps? just wondering if anybody knows?
    commsirac is offline Banned
    vx
    Aug 2007
    My guess would be that the driven gears are different on the higher pressure unit, to create higher pressure the volume that the pump moves out has to be higher.
    Other alternative would be its for a different viscosity oil, but probably not.
    One concern is that I would never put my house on anything written in the Gregory's manuals........they have been wrong before(dangerously wrong)...........
    Apr 2006
    Auckland NZ
    Quote Originally Posted by commsirac View Post
    there is that. also consulting a haynes manaul including VS
    all except 1991 VN series 275kpa (40psi) warm
    1991 VN series 375kpa (55psi) warm
    however i can't find any mention of the max pressure for either or what the pressure releif spring lenght should be????
    i guess maybe fitting a presure releif spring for a 1991 VN and see what it does is the easiest option. i am certain that the later model does have the increased max pressure however if you read it as per the haynes it suggests that the later models (V6 upto 1998 covered by the same manual) actaully run the lower pressure again???? odd
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    im pretty sure that the springs are interchangeable..like most places will just sell ya the series 2 spring anyway..as far as i know and herd the spring was mad bigger to make the pressure higher and are interchangeable with series 1....the timeing cover is not however as it has different coolent passagees or something
    Apr 2006
    Auckland NZ
    Quote Originally Posted by jas98 View Post
    yeah, i'll probably just fit a s2 spring and see what it does
  1. Vs water pump - Electric pump.
    By Lazin in forum V6 Development And Modification
    Last Post: 06-05-2011, 07:08 PM
  2. VR Oil Pump
    By yomikey in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-04-2007, 05:06 PM
  3. oil pump
    By Meerkat in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-12-2006, 07:56 PM
  4. VR vs VN a/c pump
    By falcomwreck in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-12-2006, 08:16 PM
  5. 202 oil pump
    By craigvk in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 01-05-2006, 10:11 PM
