Results 1 to 7 of 7
Thread: Trouble with HVAC again...
    02' VX Berlina 5.7L
    Feb 2005
    S.E Melb
    Default Trouble with HVAC again...
    Need some help with an issue thats driving me nuts... I had another thread about getting a little white thing for the HVAC controls, as I snapped the other one. I got one, no worries. But when I put the new one on and tried to turn the controls from cold round to hot, it won't budge....
    I have tried manualy turning the valve with my hand, and it's stuck fast.
    Has anyone had this problem, or could anyone shed any light on to what could be causing it? Thanks
    Sam
    Keesh's Avatar
    Keesh is offline WATSON HOLDEN
    VQ 5L Caprice, WH LS1 Statesman, VN 5L Calais
    Jan 2006
    did you clip the rod back in?
    Don't blame me, It's that damn percadan..
    If you ask me, that stuff rots your brain...
    And now a word from our new sponsor.. Percadan? oh crap!
    VP Exec
    Jun 2005
    The post is a bit old but...
    The rod has to be in the correct location when the clip is refitted. The dial has to be turned to the full cold position and the plastic arm has to be pushed all the way back to close the vacuum valve (under the dash, behind the heater controls) before clipping the rod in.
    Last edited by Cheap6; 30-04-2008 at 09:56 PM. Reason: Corrected nonsensical post.
    Keesh's Avatar
    Jan 2006
    posted a week ago? mayb hes still driving with no heater loll ive seen worse.. u can usually tell by looking at the rod, theres like a nice shiny spot where it was clipped in 20 years ago loll
    02' VX Berlina 5.7L
    Feb 2005
    S.E Melb
    Haha.. Yer, still driving around freezin my nuts off!
    I put the rod back into the white clip thing. Even by trying to turn it by hand, it won't budge. What I am thinking it might be is something blocking the flap that releases the hot air into the system. If so, i'll have to remove the heater box, which means whole dash must come out!
    Cheers,
    Sam
    VP Exec
    Jun 2005
    Will the dial move without the clip on the rod? The rod may be catching on something where it passes through to the lever/clip.
    Alternatively, will the plastic lever the clip is in move with the rod disconnected? The lever is connected to the vent control flap.
    02' VX Berlina 5.7L
    Feb 2005
    S.E Melb
    Nope, tried that. The clip, won't turn by hand. Tried with the motor running, with the motor warm, holding open the heater tap.... The pipes going to the heater core are hot, so it's not a blocked core. I'm thinking it could be as simple as the vent control flap being jammed somehow...
    Thanks
  1. HVAC Controls...
    By SAMO-87 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-04-2008, 01:52 AM
  2. Removing Heater Box/HVAC Box
    By 1991_Vn2nV in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-02-2007, 07:16 PM
  3. HVAC box
    By Fu Manchu in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-03-2006, 08:43 PM
  4. Having trouble
    By aw006 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-01-2006, 07:21 PM
  5. car trouble
    By panther7278 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 29-03-2005, 06:15 PM
