Results 1 to 5 of 5
Thread: what is the std compression
    CDT VH TURBO's Avatar
    CDT VH TURBO is offline CDT VH TURBO
    CDT VH TURBO
    Apr 2008
    Eastern suburbs Melb
    Question what is the std compression
    hi
    got a 5ltr VQ that won't go and I was wondering what the compression per cylinder would be for a std 5ltr in fai condition
    cheers
    CDT VH TURBO
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    You think the compression has dropped? Do you know if the starting is spark or fuel related?
    vnv8driver is offline Banned
    304 Calais
    Aug 2007
    Up your mum
    your compression would have to be extremely low for it not to fire, id be checking other possibilites.
    CDT VH TURBO
    Apr 2008
    yeh thanks, I know it's not compression related, I have got spark and fuel, too much fuel I think as it's got a big fuel pump (just put in to get it going) and plugs are as wet as
    I think it's washing the spark away, anyhow I did a compression test at 135 psi at each pot and I wanted to know if that was fair or low
    plus last night I doubled checked all the leads and found they had put the leads back on the cap one slot out so 1 was in 2 and so on
    hope to see if she will fire tonight
    cheers
    CDT VH TURBO & now VQ5ltr
    Tom_1569's Avatar
    Tom_1569 is offline Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    A compression test should always be done when the engine is warm not cold, so try it again after you get the car running.
    135 isnt to bad, just showing its age, if all pistons are close to each other thats good, its when you have all different reading you know you have trouble.
    For e.g. my paddock bomb current has (3 cylinder engine) its got 45,30, 140 so theirs definitly something wrong, in this case its just a blown head gasket.
    Quote Originally Posted by alien View Post
    I have been hit by oil badly once while in Army uniform on a massive roundabout that doesn't exist anymore. Spun 180 degrees to face oncoming traffic.
  1. increasing compression
    By johnvtls1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-04-2008, 01:53 PM
  2. Compression
    By Reaper in forum V8 Development and Modification
    Last Post: 04-01-2008, 11:25 AM
  3. Compression Testing
    By stmcomms in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-11-2006, 06:20 PM
  4. what compression v6??
    By bec22 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-08-2006, 07:40 PM
  5. Too Much Compression?
    By Stranger in forum General
    Last Post: 26-02-2006, 02:02 PM
