Results 1 to 18 of 18
Thread: no heater and central locking
    Dec 2007
    Default no heater and central locking
    hi guys, my heater only blows cold air in the vp, doesnt matter if cold or heat setting. heater taps been replaced, there was a crack in the vac line from pipes to throttle body which has been fixed and even the white part that the dial rod is moving.
    can anyone give me ideas please. in the radio area i can hear something hissing when the cars turned off even using the fan.
    also my back left central locking motor doesnt work either. whys that. if its the motor can i buy ford central locking acuators and wire them to ford spec and patch them in (No smartlock) and still keep the holden keys as the ford acuators are only acuators.
    or can i get a cheap individual acuator from jaycar
    AirStrike's Avatar
    AirStrike is offline Site Administrator
    2009 G6ET
    Jun 2003
    Why do you want to use ****ing ford parts!!! **** off with the ****ing ford bull**** you ****ing retard!!!
    Selling FG G6E Turbo and buying a N/A Supra
    Tom_1569's Avatar
    Tom_1569 is offline Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    Major EDIT, just realised who it is asking lol. My bad, i promise to be awake to thie babboom in the future.
    Damn hes got me a few times now, **** being genuine with this prick. BAN
    Quote Originally Posted by alien View Post
    I have been hit by oil badly once while in Army uniform on a massive roundabout that doesn't exist anymore. Spun 180 degrees to face oncoming traffic.
    Dec 2007
    because FORDS ARE BETTER THAN HOLDENS WITH THE AMOUNT OF PROBLEMS HOLDENS HAVE, NEARLY 500 DOLLARS FOR A WINDSCREEN AND BONNET HINGES AT GARLAND CRASH REPAIRERS KADINA AND NEARLY 400 DOLLARS AT ROSEWARNES HOLDEN KADINA FOR A IGN LOCK, NOW FORDS DONT HAVE ANY OF THOSE PROBLEMS WE HAD A ED FUTURA AND NO TROUBLE WITH BONNET HINGES OR LEAKING TAIL LIGHTS OR POWER STEERING RACKS LEAKING OR ANYTHING LIKE THAT AND THATS WHY IM GETTING A ED FAIRMONT BECAUSE I LIKE FORDS BETTER AND NO PROBLEMS WITH THE ACUATORS AND ONE OF MY HOLDEN ACUATORS DONT WORK SOMETIMES.
    the reason for the ford smartlock just for keyless entry is because the adelaide jaycar keyless entry kits are nearly 60.00 an im not spending that if im selling the car if i can get a 2nd hand module and remotes from upullit elizabeth or lonsdale.
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    Sell your VP then, problem solved. Its a POS and always breaks so why fix it?
    Dec 2007
    well mechanically it runs great for the amount of kms(268000kms) but only just wants a little tyding up and i got to save for the eb2/ed fairmont first than i can sell this one, but i have to save like everyone
    VN Calais 5L
    Dec 2006
    Blown V6 Hatch's Avatar
    Blown V6 Hatch is offline Too many projects.....
    VN Calais 5.0, UC Torana hatch 383, WB Ute 5.0
    Jun 2005
    Cowes, Phillip Island
    You need to save to buy a EB Falcon?? Man they are worth nothing.....Sell the VP and buy 2 or 3 EB's with the money!
    As for Fords not having problems, who are you trying to kid?? I am yet to see a Ford without an oil leak......Generally, they are covered in anti rust agent (oil).
    Go to the Ford forums, stop posting meaningless crap here and leave all of us alone!
    hakhawk's Avatar
    hakhawk is offline smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    Quote Originally Posted by shonky12 View Post
    high priced wreckers and dealerships isnt a car problem. if you could actually learn how to shop around, and try different places, you mightve had better luck.
    i paid $200 fitted for a windscreen, ignition barrel for $150 from memory from autobarn, the hinges in all 3 commodores ive owned have never given me trouble, and imsure can be had for stuff all at a good wreckers.
    now that you have stated your intentions and preferences to car brand, can you please move onto a ford forum and leave us in peace?
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    Why isnt he banned?
    Dec 2007
    when i get a ed fairmont i will leave you alone but until then no and i live in sa and i cant always get a eb fairmont what you say there worth and good eb2/ed fairmonts are worth 2 grand mor more in sa
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    If your fair dinkum about fixing your car, i MAY have a central locking actuator you cna have for 15 bux + postage. BUT you will have to wait and see which ones another memeber needs, as he needs three so if he only needs one back one then i have a spare.
    '97 VS Commodore + '98 E36
    Apr 2005
    champ, i got a set of passenger side actuators (front and rear) from a VR
    not too sure if the looms are the same but you could always re-wire 'em
    PM me and we can organise something.
    Dec 2007
    thanks for your concern, i have a drivers front side acuator i might try in the rear passanger and just use the wires needed and cut the rest off unless it wont work, ill have a look locally first and see how i go
  15. #15
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    Drivers front is different to the rears. BOTH rears are the same, but BOTH front ones are different even passenger and driver are different in the fronts. I can take photos if you like.
  16. #16
    BANKS's Avatar
    BANKS is offline DW I'm a Spray Painter!
    VZ SSZ Ute
    Aug 2007
    Gold Coast QLD
    My rule, always get 3 quotes as a minimum.
    Our spare car is an ED Fairmount, 600000k's on the clock still on the same heads, diff, gearbox everything. The only thing that goes wrong with it is that the power steering pump leaks and drips onto the alternator, which then kills that as well.
    Just a question, if you owned a ford in the first place, why did you switch to Holden?
    VZ SSZ- LS1
  17. #17
    Dec 2007
    [QUOTE]Just a question, if you owned a ford in the first place, why did you switch to Holden?[QUOTE]
    only because my oldman wanted to
    [QUOTE]Drivers front is different to the rears. BOTH rears are the same, but BOTH front ones are different even passenger and driver are different in the fronts. I can take photos if you like.[QUOTE]
    Tom_1569 will the drivers front from another vn work in my vps rear left door if i just used the slave wires and cut the rest off or am i best to buy a cheap acuator from jaycar in adelaide or kadina computers/electronics
  18. #18
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    [QUOTE=shonky12;764890][QUOTE]Just a question, if you owned a ford in the first place, why did you switch to Holden?[QUOTE]
    Wiring wise i have no idea, i think the front has more wires but i may be wrong. They are physically a different size and so is the little bit on the end. I have no experience with after market actuators so i cant really say.
    These are the seperate types of actuators:
    Front Passenger
    Front Drivers
    Rear Both (Passenger and drivers are identical even same part number but only for rear)
  1. central locking?
    By jet_pilot in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-12-2007, 10:49 PM
  2. central locking in vn
    By Zuicider in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-02-2007, 07:47 PM
  3. HELP!!! central locking!!
    By Snotty in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-12-2005, 09:30 PM
  4. DIY Central Locking
    By s_pack in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-08-2005, 12:34 AM
  5. VR Ute Central Locking
    By terex-demag in forum Electrical Wiring / Questions
    Last Post: 26-08-2004, 05:30 PM
