Results 1 to 6 of 6
Thread: clunking noise lhf???
    VN series II custom :) and VZ exec
    May 2005
    Mildura
    Default clunking noise lhf???
    hey everyone, just the first week of my holidays down in ballarat i noticed a clunking noise in the left hand front of my vn, when i grab the wheel at the top i can jolt it really hard and makes the noise pretty loud, when i jack it up from the body and let all the suspension hand down it doesnt make any noise, i checked all the sway bar links and are all good, ball joint looks ok but i will double check that tomorro, i jsut replaced the front shocks about 3 months ago so im just thinking it could be the nut that holds the shock come loose or something, jsut wondering if anyone got any ideas of what else it could be and also if anyone knows anyone around ballarat that is any good, like mechanical wise???, and good workshops around, if i was at home i would check it at work, but its a long way home so i got no hoist or nothing,
    cheers, nick
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    yes definally check that big nut that holds the shocker in as me sisters vp had a pretty bad clunking sound from the front rightand i could pull the wheel and could hear a big clunk noise but only when the car was lowered...not jacked up. its easy to check...jack car up on that side (and place a stand under car...never rely on a jack) and you will be able to cut the cable tie and pull the boot up exposing the shocker/nut....if this is loose fix ASAP (big mutis and some lock tight) as it rooted me sisters shocker on the front in no time
    however it could also be the wheel bearings etc... but what you are describeing was exactly the same as what happened with me
    vnv8driver is offline Banned
    304 Calais
    Aug 2007
    Up your mum
    May 2005
    Mildura
    yeah wheel bearings are good, and ball joints dont look to bad, its pretty noisy cos i can here it when i drive over any little bump, with all the windows shut well im going to have a look at it today,
    May 2005
    Mildura
    well done it was the nut on top of the shocker housing, all tight now, so i will see what happens, thanks for everyones help, jsut wanted to get some different ideas so i could look at everything else,
    cheers, nick
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    glad it was sorted
  1. clunking noise and vibration
    By igs_rodino in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-03-2008, 01:31 AM
  2. Clunking noise
    By mosone1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-02-2008, 05:11 PM
  3. vt clubsport clunking noise
    By gazzabrizz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-05-2006, 03:11 PM
  4. Clunking Noise
    By blade_1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-04-2005, 12:57 AM
  5. Clunking noise in reverse
    By ryan_VL in forum VL Holden Commodore (1986 - 1988)
    Last Post: 23-02-2005, 12:41 PM
