hey guys, my car runs on dual fuel (v6) and i put a v8 throttle body on minus the mixer (run on petrol). the car bogs down when i take off. it used to do this b4 i screwed my alternator but after i changed it, it was ok. my fuel pump is really noisy and i am led to believe that this may be the problem? or could my 2nd hand alternator my uncle gave me rooted? thanx
check your fuel filter and pressure.
fuel filter was replaced about a year ago. pressure...how do i check this? as i said in my 1st post, when i changed my alternator over it wasn't doing this. :S
-George
Fuel filter should be changed more often...
Shut up when I'm talkin' to you, you hear me, answer me!
how hard is it 2 get 2? and how long is the job?
-George
10 min job, its above the diff on the drivers side of the car. Jack it up and crawl under!
ok sweet...thanx for that!
-George
Don't forget to depressurise the system, or watch your eyes
Illegitimi Non Carborundum
what is the recent serivice history of the car?
the car is due for a service this week...changing oil, oil filter and fuel filter.
-George
if plugs, fuel filter, etc are on the list then get the car up to scratch service wise then work form there. you never know the problem may be a faulty service item.
your not getting a battery light are you?
does the car start easily.
car starts first time every time...havnt had the battery light come on, so i doubt its the alternator...im gonna service it this week oils, oil filter and fuel filter. plugs werent done too long ago.
-George
my car bogged out in the low revs when i first bought it. a new coil pack fixed it.
check your spark plugs. Are they right gap and heat range??
