Searched and couldn't find the answer...
VP Calais V6, driving home today my power steering cut out around a corner and the steering went really heavy. I went to pull over but as I did the power steering was fine again
Anyway I checked the fluid and all was fine- plenty in there, no weird noises from the pump. But it did it several more times on the way home. Now before I kill someone what is wrong with the steering? Its dangerous at the moment!
wtb: rockford fosgate sub rfp 3412
Perhaps the drive belt has stretched beyond it's limit. Check the indicator on the tensioner.
MY RIDE
I just read in another thread where someone had the same problem as you and he took it to Holden where they reset the BCM and fixed the problem. Assuming you have the speed sensitive steering, try resetting the BCM.
MY RIDE
speed sensitive steering was available on vq s2 only werent they?
park your car and turn the wheel, if you cant hear the pump working then its dead. if not get the steering rack checked out.
mate like in the other thread, your vn pump if it hasnt been rebuilt is getting on near 16-17 years old so its a fair bet the seals have hardened inside the unit and when you turn the corner and put it under load the fluid just gets past the seals .i went to holden and for $19-35 got a rebuild kit and took about two hours to do and they work like new and no leaks or noises. i think there is even a thread on how to as well. good luck
I have to reset my bcm every couple days to fix my pwr steer.
It just stays on low boost.
Sumtimes i have to reset it a couple times a day.
I do get that problem with really heavy cornering sumtimes if ur doin over 60km other times its light as.
Im not sure how to fix tho i recon its either BCM or rack, gotta put a tech tool on to find out what the go is i recon
if the bcm did make a differance when you reset it then your pretty spot on to hitting the nail on the head! youll have to go to holden for matching bcm specs to your car wouldnt you?
Im starting to have the same problem in my VR. Only at low speeds tho, like when I turn into my driveway or parking the car.
Shut up when I'm talkin' to you, you hear me, answer me!
^ that sounds like a speed sensitive problem
How do I reset the BCM then?
mates next door neighbour is wreaking a vp calais and he has the power steering rack left over. i think he wants 40 -50 dollars for it. its in perth
I talked to Davie Parts in Auckland about power steering, and they convinced me there was no such thing as a Holden kit for racks or pumps. So if you guys can get them cheap over there i'm gonna be mighty ****ed.
JetSpin Racing Team Mantre:
"F**k safety, I'm in a hurry"
