Results 1 to 3 of 3
Thread: Auto Trans: filter seal?
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Question Auto Trans: filter seal?
    Hey dudes, quick question here:
    When servicing your T700 auto, you remove the filter - and the filter neck has an orange rubber ring on it, to seal and secure it.
    1) the old ring didn't come out, and I can't prise it out. It's now butchered and I have to remove it, but it won't budge. Even with small sharp things. Any tips?
    2) the old ring, still mangled and stuck in the return line, appears to be three layers: rubber, metal, rubber. Is this correct, or am I starting to butcher stuff that's kinda permanent? I've been trying to peel the rubber off, and also appear to be peeling metal. There is, however, rubber behind and in front of this metal. Is there supposed to be metal inside this o-ring?
    Thankyou so much in advance
    The 1972 HQ Kingswood
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    hrmmm, did u try sticking the old filter back up there and wiggle it round, thats what'd i would do,
    Morton i don't think the filter is the return line, i think its the feed line
    Morton's Avatar
    May 2006
    Could well be the feed line I just made that bit up to give peeps an idea of what it looked like ^_^
    But I got the little seal out in the end. *wipes brow* It was indeed half metal.
    Flathead screwdriver + lump hammer + effort = winnar.
    All in all, a bitch of a job to do, but worth it. Nothing better than the feeling of driving a car with fresh engine oil, trans fluid, spark plugs and air filter.
    And yeah I did try that, para. No luck. But is all good now
    Thanks anywho!
  1. Auto Trans problem when hot - need a trans cooler ??
    By woteva in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-12-2007, 11:41 PM
  2. VR auto Trans
    By WILD VR CLUBBY in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-08-2006, 01:16 AM
  3. VR Auto Trans
    By sicko in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-05-2006, 11:18 PM
  4. auto trans. rear seal
    By VN-88 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-10-2005, 08:01 PM
  5. Auto trans filter change problem
    By hako in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-08-2005, 10:48 PM
