Results 1 to 17 of 17
Thread: Exhaust
    5sp VN Executive1988, VX SS 6sp
    Apr 2006
    canberra
    Default Exhaust
    Hey my exhaust is cracked on the 'Y' piece where the 2 pipes join just before the cat. If i rev the car in neutral, when the revs are dropping I can hear a hissing noise and im guessing its air escaping or getting sucked into the exhaust. Would this be right? and would it have caused any damage to cat? Its been like this for a few months now. car still runs fine. I called exhaust place to see how much a new 'y' piece was, and its gona cost me $240 to get it replaced. This sounded expensive to me. how much should i be paying? cheers.
    Australia. Love it or leave it
    vn calais, vs clubsport #137
    Jun 2005
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    Dan355's Avatar
    Dan355 is offline Go THE SS's
    Street Legal 355ci VN SS - Daily: VP SS
    May 2006
    VP Exec
    Jun 2005
    It's pretty common for that to happen on S1 VN's (the exhaust mounting is different on later models).
    Can't it be welded? It would take longer to put the car on a hoist than to run the weld - < $50
    DanVN's Avatar
    DanVN is offline Cruizin' in style!
    01 WH Statesman International 5.7L
    Nov 2007
    Western Suburbs, Vic
    So Thats what that noise is on my car .... always suspected it was a exhaust leak
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    if your in perth i have a mig welder at home and i can have it fixed for u in a jiffy for nothing
    Tom_1569's Avatar
    Tom_1569 is offline Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    Quote Originally Posted by Zuicider View Post
    Would anyone trust this fool with a welder near petrol lines and their car lol.
    Quote Originally Posted by alien View Post
    I have been hit by oil badly once while in Army uniform on a massive roundabout that doesn't exist anymore. Spun 180 degrees to face oncoming traffic.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Why make a comment like that.
    Chances are the pipe is crystalised, that could be why it is leaking. You could try getting it welded, but be prepared in the event that it needs replacing. Ring around, get a few more quotes. It is the dearer of the two engine pipes, because it has the flange for the cat and it is quite long. Also try a wreckers for a s/h part.
    Visit my Facebook page
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    weld it up you idiot lol.... dosnt take a genuis to realise you need to take the Y peice off the car first to get a good weld / clean it up... has everyone left their thinking caps on the bus?
    you can even weld in a fillder section but i dont see why you cant weld that up
    Apr 2006
    canberra
    I already got a redback catback exhaust for $300 thats why i thought it was a bit steep priced for the Y piece. Havnt had time this week to call around. Gona try weld it up today if that fails gonna have to ring around a few places next week.
    Apr 2006
    canberra
    I welded up the crack fine, but still makes a kinda hissing noise while the revs are dropping after i rev it in neutral. I had another listen and it kinda sounds like its coming from the cat converter. Is it possible for exhaust gases to leak out of the cat somewhere?
    My car also sounding bit different the last few months. not as good as it sounded when i 1st got exhaust done. Is taking taking the cat off as simple as undoing the bolts and sliding it out, or is there more to it?
    Jun 2005
    its pretty much that easy, u may need a wedge or screw driver to pry it off a little. but its fairly straight forward.
    Apr 2006
    canberra
    Are there any gaskets or anything that i will have to replace when i put it back on? and if its stuffed, would a 2nd hand cat be good enough because i think there pretty expensive new
  15. #15
    Jun 2005
    a second hand one should be fine aslong as its not as blocked or stuffed as yours . if you have a good wreckers around try get a hold of a gen 3 cat and have that flanged to suit your car. for a slight gain .
    they use a gasket of their flanges usualy. exhaust shops should stock these.
  16. #16
    Steery's Avatar
    Steery is offline AA 554 G
    94 VR SS M5
    Feb 2008
    Adelaide, near Cross Road Maccas.
    Quote Originally Posted by coolvncommodore View Post
    geez 300 for a redback, thats a bit steep..
  17. #17
    Apr 2006
    canberra
    Quote Originally Posted by Steery View Post
    Pretty cheap here in canberra. I got quoted up to $470 for it.
  1. Wanted VS V8 exhaust / HSV exhaust / Merge pipe
    By prettyboringbloke in forum Swap / Wanted to Buy / Trade
    Last Post: 21-02-2008, 03:06 PM
  2. exhaust
    By VY Rollin on 20's in forum V6 Development And Modification
    Last Post: 23-12-2006, 11:24 PM
  3. List Of Exhaust Quotes no it's not another exhaust question:)
    By Thomas1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-11-2006, 08:57 AM
  4. VT Exhaust (not jst another exhaust thread)
    By raZel in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-09-2006, 03:50 PM
