Results 1 to 7 of 7
Thread: changing front springs
    vn 5.0
    Apr 2008
    Default changing front springs
    do u have to take the whole strut out or is there an easier way???
    UNKNOWN's Avatar
    UNKNOWN is offline DEFECTED
    95 VR SII BT1 5 Speed
    Jan 2008
    NW Adelaide
    whole struts gota come out.
    Shut up when I'm talkin' to you, you hear me, answer me!
    vn 5.0
    Apr 2008
    UNKNOWN's Avatar
    Jan 2008
    NW Adelaide
    Still gota take the strut out to get the spring off of the strut, you have to compress the spring so you dont break anything (window, face!) when you undo the top of the strut to get the spring off.
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    You can do it without completely removing the entire strut, but its usually just easiest to do it that way, the only thing that can be a pain is the lower ball joint (sometimes tricky to separate from the strut) and you can drop the strut under the guard by unbolting the lower control arm from the k-frame and possibly the radius rod and changing the spring like that.
    Power is measured in DECIBEL
    VP Executive R-spec
    Jan 2005
    I pull mine out the side of the gaurd to save ball joint trouble leaving the strut attached at the bottom, it's a hassle but doable . I've done it a few times like that
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    i drop the strut and lower control arm together (again saving the balljoint hassle) but need a 30mm socket for the nut that holds the radius rod through the control arm. also need a decent power bar or 1/2" rattle gun at this baby is loctited to stop it coming loose
    you can get the standard spring off without a spring compressor but it's a risk as there is a fair amount of load on it. i lay it down on the grass with my foot pushing the strut mount down, that way when it lets go the strut top digs into the grass without doing any damage anywhere. low/superlows springs don't require a spring compressor to fit on a again
    Body by Holden, Soul by Brock
    the Legend will live forever
  1. changing front springs in vn
    By Gav86 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-10-2007, 01:57 PM
  2. Changing Front Springs
    By rian in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-01-2007, 04:31 PM
  3. Changing Springs - How do I...?
    By grimavxs in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-11-2006, 08:58 AM
  4. Changing springs in a vx
    By Charg'd in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-10-2006, 11:25 PM
  5. Changing Springs?
    By Shifty1 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 27-12-2005, 12:40 PM
