Results 1 to 11 of 11
Thread: Seized auto transmission?
    vn calais
    Dec 2007
    Default Seized auto transmission?
    Was driving my vn the other day and it just stoped, now the starter wont turn it over but i can turn the engine by hand in reverse, but not in the clockwise direction. So its not the motor, any ideas most appreciated!
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    How is your battery and terminals? Check to make sure all the connections are clean and tight. Do you have dash lights? Turn the ignition to on and turn your headlights on and see what happens.
    Visit my Facebook page
    vn calais
    Dec 2007
    yeah that was my first thought so i tried jump starting it, but the same problem. I cant turn the engine over by hand (with a socket and breaker bar) in a clockwise direction.... The only thing i can think of is the tranny?
    jetspin_vn's Avatar
    jetspin_vn is offline JetSpin Racing Team
    VN GTS
    Nov 2003
    Mission Bay, Auckland, New Zealand
    Did it cut out whilst driving? Could be the start-in-gear prevention circuit.
    JetSpin Racing Team Mantre:
    "F**k safety, I'm in a hurry"
    burnz's Avatar
    burnz is offline dah dut dut da dah
    2010 CRUZE Diesel
    Jun 2005
    springfield
    Quote Originally Posted by Beav1s View Post
    doesent sound good.
    broken tooth on counter balance?
    a leg out of bed?
    Research has shown that men usually sleep on the right side of the bed.
    Even in our sleep we happen to be right.
    Powered By Garrett
    jetspin_vn's Avatar
    VN GTS
    Nov 2003
    Actually, can you hear the starter solenoid click when you turn the key?
    vn calais
    Dec 2007
    Na its not the starter, it stopped whilst it was driving.
    Does the v6 have a counter balance shaft?
    Thought it is strange though how i could turn the motor over by hand in reverse, and then as soon as i try to turn it clockwise by hand it offers too much resistance.....
    Suppose there could be something inside the motor fouling the rotation.
    Has anyone ever encountered this before
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    It will have resistance turning it by hand because of compression. Take all the plugs out and try turning it.
    I still think it is electrical, either alternator and it drained the battery or loose/dirty connections.
    jetspin_vn's Avatar
    VN GTS
    Nov 2003
    You'd expect a charge light if it were alternator. Still I think your right about it being electrical.
    VNV6VENGEANCE's Avatar
    VNV6VENGEANCE is offline VeNgeance
    VN Turbo
    Jan 2006
    adelaide,sa
    Get your ecu checked for fault codes. If its electrical might pick up the problem.
    only good cops a dead cop...
    s1 vn commodore turbo
    t3/t4 front mounted turbo
    Intercooler ---3"exhaust
    stage 2 shift kit---B&M Qicksilver shifter
    3:45 lsd
    18" Cv8z Monaro rims 245's
    vn calais
    Dec 2007
    Thanks for all your input guys, turned out to be a seized alternator, we loosened the belt and then it turned over no probs.
    Crazy something so simple can freeze the whole engine, the starter just didnt have the power to overpower it!
    Thanks again
  1. VZ SV6 - Auto Transmission
    By s0sage in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 12-05-2011, 12:01 PM
  2. WTB - VN auto transmission [vic]
    By timmy_tam in forum Swap / Wanted to Buy / Trade
    Last Post: 26-03-2008, 08:08 PM
  3. Code 68 - Transmission Component Slipping - Auto Transmission Only
    By tysons_2001 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-12-2006, 05:14 PM
  4. vt transmission auto
    By wal in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-06-2005, 04:18 PM
  5. Which Auto Transmission?
    By James Collins in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-04-2004, 01:40 PM
