the old girl have done 285 000k this week and since it already is due for a service soon just wanted to know what might need looking at or whats on the way out usually. so far doing oil/filter fuel filter, air filter, plugs, plug leads. thats all i can think of atm.
oh btw its a s1 vn 5speed Manuel
cheers
opinions are like a**holes, we all have one
gearbox oil, diff oil, a bottle of injector cleaner wouldnt go astray either.![]()
cheers any particular brands or anything
Can of throttle body cleaner as well. With the diff oil, make sure you get a new gasket or some gasket paper, and watch the bolts. The diff housings are a little soft on borg warners and can easily be cross threaded.
JetSpin Racing Team Mantre:
"F**k safety, I'm in a hurry"
The 1972 HQ Kingswood
Morton, i hate to be off topic, and i hate when someone has damage done to their car, but everytime i see that sig i cant help but laugh
And thanks for some of these suggestions, my car is coming upto 230,000 and will need some work.
haha, that's alright man. It's there to be laughed at. I can't say I didn't crack a smile when I was making it. If you can't laugh at the crazy misfortune in life... well... then you're probably british.
But yes, the other obvious things to do on every service interval, is take all the wheels off and inspect your brake rotors and pads - and clean/replace the grease on the caliper slides. Also regrease the front wheel bearings while you're there - it can never hurt.
Degrease everything thoroughly, and after your service, take her for a quick spin and check for leaks everywhere. Check the condition of oil hoses, water hoses, coolant hoses... and remove the drive belt, and check if all the pulleys spin smoothly.
that's the major stuff anyway![]()
mate for a 285,000 service you would want to be going over the entire car, checking suspension components, changing all fluids (engine/auto/diff/coolant, leads, sensors, spark plugs, air/fuel/oil filters, cleaning out the throttle body, giving the motor a degrease snd checking for oil leaks, maybe some new mufflers?
thanks for the advice so does the diff housing need to come off?
Nope. You should only have to undo the bottom bolt, and all the oil will come out through it.
take the whole backing plate off if your keen, clean all the built up sludge and check out everything
