Results 1 to 12 of 12
Thread: Statesman Map Light Under Blind
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Default Statesman Map Light Under Blind
    Any one fitted a Statesman map light that goes under the passengers blind to a VN?
    I have the map light - but before I start cutting - a photo of where it go's would be great - or if it cant be fitted becuase there is no hole for it.....
    Any info would be cool.
    and 3 Dangerous non ABS VN's
    88GreenVN's Avatar
    Jun 2006
    Cant up load the photo's - bummer.
    88GreenVN's Avatar
    Jun 2006
    This is the light I'd like to add the the 91 VN V8 Commodore
    PRH
    PRH is offline
    vp s utility,and a KENWORTH
    Apr 2007
    Mildura Victoria
    Ther is'nt any brackets or anything the light just mounts in the lining itself,when me daughter brings home me ute i'll get some pics and measurements if ya like
    Phillip
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by PRH View Post
    Phillip
    Hmm thanks that'll be great.
    I fig it had to be in the correct spot and well cut out else it would fall out. So just didn't want to hack into it (like when I was a youngster) and hope for the best.
    STEALTHY™'s Avatar
    STEALTHY™ is offline So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    How easily could you wire that light up to the spot on the rear of a VP Calais. I bought some thinking they fit (cause i like the push in ones, not the switch) but they don't even fit in the hole.
    ATM theres no light in there, cause i broke the old ones (well, they were pretty **** when i got the car, pulling them out just helped them fall apart)
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by STEALTHY View Post
    Easy as. I used a old spotlight plug and soldered the 2 wires up. Orange to power, wire to door switch and black to earth. Look at my 91 VN V8 - fitted extra lights in this week just gone.
    I recond if you take the plastic holder out the hole would almost be the correct size.
    STEALTHY™'s Avatar
    Jan 2005
    Figured it would be a simple wire job.
    I'll see if i can find the light i have, but when i looked, it seemed to have quite a large plastic thing on one side, that made it difficult to fit.
    I have a Stato roof clock (well, 2 lol) i need wired up, so i guess i'll get it all done at the same time
    cheers sexy
    PRH
    PRH is offline
    Apr 2007
    Mildura Victoria
    ok got the measurements,its 145 mm to the front edge of the light from the leading edge of the lining,and 65 mm from the edge of the light to the bracket that holds the sun visor,got some piccies IF I CAN LOAD THE BUGGERS
    Phillip
    Attached Thumbnails Attached Thumbnails Statesman Map Light Under Blind-100_2696.jpg   Statesman Map Light Under Blind-100_2697.jpg
    PRH
    PRH is offline
    Apr 2007
    Mildura Victoria
    88GreenVN's Avatar
    Jun 2006
    Your a champ mate - I would have started completly in the wrong spot. Have some rep points on me
    STEALTHY™'s Avatar
    Jan 2005
    Rep from me too. Wanted a pic of a clock i the car, so i can get mine mounted up.
    cheers sexy
  1. am i blind.
    By pr0n in forum General
    Last Post: 19-03-2007, 10:26 AM
  2. vs statesman blown bulb warning light
    By evil_monkey in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-02-2007, 07:22 PM
  3. Blind Man
    By holdensupporter2005 in forum Jokes/Humour
    Last Post: 15-11-2006, 10:52 PM
  4. Venetian Blind for vn
    By [SIK-GMH] in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-10-2006, 10:27 PM
