Results 1 to 5 of 5
Thread: Brake/tail lights.
    mischa's Avatar
    mischa is offline <- 245rwkw Holden V8
    VN V6 T5 - 355 VN GRP A REP T56
    Jun 2005
    Ashbury, NSW
    Default Brake/tail lights.
    Ok, thought i would try and fix this problem as i get complaints about it.
    To start ill tell you what the car is like LIGHTS ON and BRAKES OFF.
    The 2 bottom rear lights will be on, the 2 above that sligtly dimmer and the parcel shelf light will be the same brightness as them.
    (taken to sets of photos one with and one without flash i dont know what turned out better)
    Now for LIGHTS ON and BRAKES ON.
    The 2 bottom rear lights will be brighter inicating brakes, the 2 above will be OFF and the parcel shelf will be brighter indicating brakes aswell.
    I have my theories but with out knowing the wiring or having a diagram im lost.
    Thanks.
    Quote Originally Posted by keza87 View Post
    Really who wouldn't want to give Jack a good smack in the back of the head.
    The Daily VN T5V6
    355 VN GRP A REP
    PRH
    PRH is offline
    vp s utility,and a KENWORTH
    Apr 2007
    Mildura Victoria
    go buy a new tailight lume from gmh and plug it in, jobs doneyour lights have rusted globe holders normally due to leaking lenses
    Phillip
    mischa's Avatar
    Jun 2005
    Ashbury, NSW
    There's no corrosion on the globe holder's at all.
    The Daily VN T5V6
    355 VN GRP A REP
    PRH
    PRH is offline
    Apr 2007
    Mildura Victoria
    Ok then try running a sepparate earth to the lights that are at fault,or make sure that the earthing lug is touching the globe base in all 4 lights
    Phillip
    mischa's Avatar
    Jun 2005
    Ashbury, NSW
    instead of starting a new thread.
    Can someone take a look in there gregorys and scan the wiring diagram for the brake lights. For some reason my gregorys dosent have the parcel shelf light in the diagram its a old manual).
    The Daily VN T5V6
    355 VN GRP A REP
  1. VT Tail lights Lights inc loom and globes!
    By Heffer_Slayer in forum Parts And Other Items For Sale
    Last Post: 03-05-2008, 06:31 PM
  2. [SA] Vs Tail lights & Tinted Vp rear tail lights and garnish
    By hothousevn in forum Parts And Other Items For Sale
    Last Post: 23-10-2007, 01:46 AM
  3. tail lights turning off when brake applied!?!?!?!?!?
    By plAythiNG in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-10-2006, 06:36 AM
  4. Dash Lights & Tail Lights fail
    By robert_buntine in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-08-2005, 05:17 PM
  5. Tail/brake Lights Warning Lamp
    By Frederick in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-01-2004, 07:19 PM
