Results 1 to 15 of 15
Thread: Brake master cylinder size
    VZ Calais
    Aug 2005
    Mackay Qld
    Default Brake master cylinder size
    Hi guys,
    What size should the master cylinder be? 1" or 15/16?
    VN SS Auto. 1990.
    What would be the result of using a 1" instead of a 15/16?
    Lower pedal?
    Any different for cross drilled rotors?
    Cheers, Col.
    Dan355's Avatar
    Dan355 is offline Go THE SS's
    Street Legal 355ci VN SS - Daily: VP SS
    May 2006
    Should be a 1" master. Cross drilled rotors are a waste of time just get slotted rotors if you have to.
    VZ Calais
    Aug 2005
    Mackay Qld
    The rotors are already on the car.
    I'me trying to understand why the brake pedal goes down so far.
    Everything works fine, just too much pedal travel.
    I thought the brake system was the same as VL Turbo, which has the 15/16 m.s.
    knowledge_is_power's Avatar
    knowledge_is_power is offline Quest for Cognition
    VT SII V6 A4
    Oct 2004
    Nth Brisbane
    Could also be fluid related. Have you flushed the system with brand new brake fluid and bleed all the air out?
    Dan355's Avatar
    May 2006
    The calipers are the same but the masters are different. 1" master for the ss should be stamped on the master.
    As mr knowledge said check the overal condition of the brakes a fluid change wouldnt hurt.
    Quote Originally Posted by coolngroovy View Post
    pow3rslave's Avatar
    pow3rslave is offline DoNothing Member
    VP 5.0L
    Oct 2005
    eastern subs, vic
    v8's had the larger (1") master. not sure on the v6 size, but it's smaller. i also have a bit of travel in mine, but i'm taking it in tomorrow (getting fronts machined, and new pads) so i'll let you know what they said the cause is for my probs.
    VZ Calais
    Aug 2005
    Mackay Qld
    I've replaced pads front & rear.
    Also bled the system.
    Is the m/s actuating rod adjustable?
    VP Exec
    Jun 2005
    Is that all you have done?
    If it is, I would suggest that it's possible you haven't bled the system in the right way (have another go at it):
    L rear
    R rear
    L front
    R front
    Do not allow the pedal to come back up with a bleed screw open.
    Don't let the pedal hit the floor. The master cyl. only travels a short distance during normal use and crud and corrosion can build up in the M/C bore where it isn't normally wiped by the piston seals. This is especially so if the fluid isn't changed regularly. If while bleeding the system you let the pedal (piston) travel far enough into the bore to contact the corrosion/crud, the seals in the M/C can be damaged.
    Really crap pads can be flexible enough to give the impression of a low pedal but I'd say that's fairly unlikely these days.
    (A 1" M/C will produce less pedal travel for the same displacement of fluid volume.)
    VZ Calais
    Aug 2005
    Mackay Qld
    I can bleed brakes. But thanks for that.
    Going to flush the fluid & replace.
    I sold my VN SS a few months back. But it was a manual.
    I bought this other VN SS auto by accident.
    The difference between pedal travel on the 2 cars is very noticable.
    VT SII V6 A4
    Oct 2004
    Nth Brisbane
    I suppose it is also possible that the disc pads can give a different pedal feel.
    If at the end of the day your still unhappy and want to replace the master cylinder the part number is P10331 and can be had for $120 - $180 if you know the right people
    jetspin_vn's Avatar
    jetspin_vn is offline JetSpin Racing Team
    VN GTS
    Nov 2003
    Mission Bay, Auckland, New Zealand
    How does one buy a VN SS by accident?
    JetSpin Racing Team Mantre:
    "F**k safety, I'm in a hurry"
    VZ Calais
    Aug 2005
    Mackay Qld
    I was looking for a set of VP GTS rims for my VS Caprice. I wanted a set in the chapagne color specifically. Didn't like my chances much.
    Then a guy i work with shows me a phone pic of a VN SS he got as payment for a bad debt. Guess what rims were on it?
    So i bought the wheels for $200, then bought the car a week later for $1500.
    BTW, these are his prices. I didn't even negotiate.
    I was just going to make a quick $ on the SS until a good m8 fell in love with it. Damn!
    We flushed the fluid out today & re bled the system. All is good.
    Brake pedal now has a lot more 'feel'.
    Thanks for the input guys, very much appreciated.
    VZ Calais
    Aug 2005
    Mackay Qld
    pow3rslave's Avatar
    VP 5.0L
    Oct 2005
    eastern subs, vic
  15. #15
    VZ Calais
    Aug 2005
    Mackay Qld
    Not wood grain, real wood.
    I think it was owned by a frustrated carpenter!
    Actually looks good.
  1. brake fluid master cylinder
    By vr-man in forum Swap / Wanted to Buy / Trade
    Last Post: 08-04-2008, 01:08 PM
  2. Replacing Brake Master Cylinder
    By dufus in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-04-2007, 09:48 PM
  3. VN-VP 1" Brake Master Cylinder
    By AlpineRaven in forum Parts And Other Items For Sale
    Last Post: 09-02-2007, 08:44 PM
  4. Brake Fluid Master Cylinder
    By Harvs82 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-11-2006, 07:19 AM
  5. Leaking Master Brake Cylinder Connecting to Brake Booster Advice help please.
    By IceDHB in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-08-2005, 02:32 PM
