have just put a v6 into a gemini, have used the pat gardner wiring kit etc. when i got the engine, it had no leads on it, what cylinder is what so i know what order to connect the leads?
also, i havent got the wiring loom that plugs into the gearbox yet, would that stop the engine from starting? (have bypassed the nuetral safety wires)
also would like to know the fuel inlet and return lines please
cheers
love the help around here.... lol
got it all sorted out, but it still not starting. it cranks, has spark, just not sure whether its gettin fuel.
i got some dodgy fuel filter off ebay, and its sendin the fuel up to the engine bay just not sure whether it has enuff pressure.
if i disconnect the return line off the fuel rail, is fuel supposed to come out when the pump is on? because theres nothing coming out of it.
does the pump have to be hooked up to a tank for pressure? cos ive only got the pump hose in a jerry can at the moment.
cheers,
firing order
. . . . . . (coil packs)
6.2.4
.3.5.1
fuel inlet goes to open fuel rail, return line comes off after the regulator
what V6/PCM you using? with the later model PCM (and BCM, VR onwards) you need the VATS deleted otherwise it won't run.
only just saw this thread lol
Body by Holden, Soul by Brock
the Legend will live forever
sweet as dude, had the lines back to front. lol. its only a vn motor/computer. so no vats...
killed the battery on the last attempt. so i gotta wait for it to charge and ill try again... fingers crossed
cheers mate.
so how'd it go?
