Results 1 to 20 of 20
Thread: hall effect sensor
    MiSs MeOw's Avatar
    MiSs MeOw is offline MiSs MeOw
    spankin 1998 VT
    Feb 2007
    Default hall effect sensor
    hey guys, my car (vn v8 manual) has been playing funny buggers on me for the past 2 weeks, id be driving along just fine, after about 20 mins of driving all of a sudden my car just dies, it takes about 5 - 10 mins before i am able to crank it over again, i have a feeling it is the hall effect sensor but i have no idea where to find it on the engine
    can someone please point me in the right direction
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    Quote Originally Posted by MiSs MeOw View Post
    hey guys, my car has been playing funny buggers on me for the past 2 weeks, id be driving along just fine, after about 20 mins of driving all of a sudden my car just dies, it takes about 5 - 10 mins before i am able to crank it over again, i have a feeling it is the hall effect sensor but i have no idea where to find it on the engine
    Its INSIDE the Distributor. Quite a bitch to get to and test. Best bet is to take it to a auto electrician and see if they can test it on car.
    MiSs MeOw's Avatar
    spankin 1998 VT
    Feb 2007
    1989 VN Commodore Executive - 5sp Manual
    May 2008
    Also check the crank angle sensor, maybe starting to fail.
    When they get too hot, they stop working.
    You can try running it till it stops then pour cold water over the sensor and try to start again within a few minutes.
    MiSs MeOw's Avatar
    spankin 1998 VT
    Feb 2007
    MiSs MeOw's Avatar
    spankin 1998 VT
    Feb 2007
    Quote Originally Posted by Mack View Post
    ohhhhh its actually the whole plate thing......just googled it
    now thats just a pain in the ass, but do u think that would be the cause of my issues?? or could it be something else??
    VP Exec
    Jun 2005
    is it that lil box thing in the distributor with the 3 wires?
    Sounds like it - black plastic and the vanes under the rotor button pass through it?
    The ignition modules (on the passenger side inner guard, above the airbox) are also a known problem.)
    Also, the wiring terminals on the connector to the hall sensor can back out of the connector but probably not if it restarts after sitting.
    Any fault codes: 42 perhaps?
    i thought 5lt's didnt have CAS they had hall effect sensors???
    Correct, although the hall sensor and distributor together perform the same function.
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    You guys got it sorted I didnt get any fualt codes when my ign module died.
    vnv8driver is offline Banned
    304 Calais
    Aug 2007
    Up your mum
    the hall effect sensor is the crank angle senor on the 5 litres. im telling you right now the problem will either be ignition module, coil or hall effect sensor... i had this problem in my statesman and after it did it a few times i went nup, replace the lot... and it never did it again, and ran sweeter than ever.
    MiSs MeOw's Avatar
    spankin 1998 VT
    Feb 2007
    Quote Originally Posted by Cheap6 View Post
    i dont have one of those computer thingy's
    MiSs MeOw's Avatar
    spankin 1998 VT
    Feb 2007
    ok well ive got a spare ignition modual and coil but i wont even attemp the hall effect sensor, would it be wiser to get a new dizzy than to get someone to change the HES???
    NORTI's Avatar
    NORTI is offline come get me
    VR Calais 5L, WM Statesman
    May 2004
    I just did this. Ignition Module turned out ot be fine, I ended up replacing the whole dizzy (I suspected the HES) & since the coil was looking like it was factory orig, replaced that too!
    Fine now. I got no codes, & very little warning that it was going to die, left me over 100km's from home when it went
    VP Executive R-spec
    Jan 2005
    You only need a paper clip
    MiSs MeOw's Avatar
    spankin 1998 VT
    Feb 2007
    thank you guys all fixed now, it was the hall effect sensor, im lucky i had a spare dizzy in the garage
  15. #15
    304 Calais
    Aug 2007
    Up your mum
  16. #16
    MiSs MeOw's Avatar
    spankin 1998 VT
    Feb 2007
    nah he didnt put it in for me, one of my mates dad is a mechanic so he put it in instead as he knew how to do the timing
  17. #17
    304 Calais
    Aug 2007
    Up your mum
    either or at least its on the road, by the way whats done to the yellow one?
  18. #18
    MiSs MeOw's Avatar
    spankin 1998 VT
    Feb 2007
    its going to stef's (STOWLN) place this week to go get all the wiring hidden, smoothed out bay, then off to christians to go get re-sprayed
  19. #19
    304 Calais
    Aug 2007
    Up your mum
    but is it stock? i seen it in a few recent pics on squaredarches (im nodg) and it had gauges on the bonnet and a few bog repairs?
  20. #20
    MiSs MeOw's Avatar
    spankin 1998 VT
    Feb 2007
    ohhhhh hey hahaha, yer still stock and keeping it that way, gauges are gone and its repairs are going to be welded
LinkBacks (?)
  1. Pogo Stick Effect in Front End
    By stockies in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-04-2008, 05:12 PM
  2. Victorian P Plate Laws - Effect. July '08
    By Frandy in forum The Pub
    Last Post: 18-10-2007, 10:33 AM
  3. Will leaky exhaust effect fuel economy?
    By Marcus G in forum VL Holden Commodore (1986 - 1988)
    Last Post: 07-12-2006, 01:19 PM
  4. effect of thermostat on fuel use
    By michaelw in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-10-2005, 10:38 PM
  5. Effect of ethanol in fuel
    By Minotaur in forum VL Holden Commodore (1986 - 1988)
    Last Post: 13-09-2005, 12:19 PM
